Are all oil pan gaskets jigsaws now? Pickup tube oring
Meathead16
TL:DR: If too much RTV was used on rear cover, will it break off and cause issues regardless of cure time? How do I go about dropping the front diff to change the oil pan gasket and pickup tube oring without damaging anything? Which pickup tube oring is the right one and are any oil pan gaskets made like the original, one piece design the truck came with?
I replaced my rear main cover due to a pretty bad leak caused by the long oil pan bolt holes being stripped out.. One would spin in a figure-8 and the other one was straight up gone. When I installed the new cover I think I used too much RTV, it squished out quite a bit on the outside and I'm worried it squished out inside as well. After the fact I found info that only a small amount is required, definitely less than I used and that the excess can break off and clog the oil pickup tube, etc. Is this mainly a concern when set time isn't long enough? Or is cure time irrelevant? It has had about a month to cure thus far.
I already have everything back together and really don't want to take it all apart again and disturb the rear crank seal and potentially have to replace a brand new part. Where the oil pan and block meet has always been a lil wet so it's probably time anyway. It's clear it's been done before but with the stripped long bolts the install probably wasn't too kosher. I'm hoping I'll be able to remove any excess rtv from the rear cover install with the oil pan out, get a new pickup oring installed, and maybe have a dry chassis for the first time since owning this truck.
Does anyone know which brand, if any, makes a one piece oil pan gasket? They all seem to be 2 or 4 different pieces that are "jigsawed" together. Even the ACDelco Genuine GM part. Looking at the stock photos of a Victor-Reinz or Mahle gasket show a one piece design, however, there was a Mahle gasket listed on ebay that had a picture of the actual sealed gasket and it was a 4 piece design. The same listing had the one piece stock photo with it too and showed the matching part number on the packaging. It is eBay though so who knows if someone took a cheap gasket, a Mahle cardboard piece and shrink wrapped it. I won't purchase from eBay due to how prevalent that practice is but it was the only place I could find a photo of the actual item.
Summit, etc. all have the same stock photos. Have all brands, regardless of their stock photos, switched to the 4 piece? I noticed Felpro seems to have a 2 piece design. Better than 4, but worse than 1.
Also, I've seen gaskets that in the corner opposite of the oil filter holes, in the front right side of the gasket, some have a group of 3 smaller holes, while other gaskets have nothing, or maybe one small hole. The stock photo below shows all 3, the actual photo shows just one. Most gaskets seem to have none. They all say they fit. Are these the rivet holes? Is that something I need to worry about? I have an iron block lq9.
Also, also, the oil pickup tube oring. Is it just the one oring where the pickup tube mates with the oil pump? I keep seeing an Oil strainer gasket, with some listing having 1 oring, while others have a kit with 2 orings. Is the oil strainer just a different name for the oil pickup? If not, what is considered the oil strainer? I've come across orange, green, and black orings. The pickup tube oring tends to be orange, while the strainer orings tend to be one green and one black, but I've also seen listings showing any combination of colors being designated as either the strainer or the pickup. Is oring color significant? I really want to make sure I get the right oring so that I hopfully never have to tear any of this apart again.
Any install tips I should keep in mind? I know the front diff needs to be lowered. Do I just loosen the bolts holding it on but not remove them? Even with the crossmember out and the drivers side mounting bolt removed, it looks like the input shaft yoke will hit the frame. Do I remove that mounting bolt and lower it to just before it hits the frame and then support it with a jackstand? I keep reading people saying to remove the bolts and "just let it hang" but I'm confused about which bolts (all of them, just the axle tube, or just the frame mounting bolt) and if I just let it hang, wouldn't that pull the cv axles apart?
TIA
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
I use Genuine GM or Fel Pro gaskets, as a rule. These look to be 1 piece.
I read your story and not once did I see mention of the 106 inch pound and 18 foot pound torque specs.
Did you have All Data to refer to for best repair procedures or did you look at multiple you tube videos?
I do know that people tend to use too much RTV.
RST Dana
EMT/First Responder Firefighter Supporting Member
OH
RTV is room temperature vulcanizing. So unless you forever below room temperature, i.e. 70ish, it was cured in 24 hours.
alexblagoev
Member Recommended
