Are 4wd lifts Compatible with a 04 2wd tahoe?
DaddiCaddi
Anyone here know if any 4wd suspension lift kits will work with a 2004 2wd tahoe?
it's currently lowered with a 3/5 belltech kit. i've been looking into lifting honestly not wanting to use a rcx suspension if i don't have too.
just spindles and keys ARE NOT A OPTION.
Alex_M
Yes. They are not optimal on a 2wd; a 2wd has the benefit of retaining stock ball joint angles with a spindle lift. However, if a spindle lift is not an option then a 4wd lift will work fine.
However, you also say keys are not an option. What type of lift are you looking at then? To my knowledge, either spindles or keys are the only lift options unless you're converting to coilovers which is much more costly.
44Dan
