Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
My daughter's rear end went out on the '95 2 dr Tahoe. Haven't come across a 14 bolt 3/4 ton but have found a few rear ends from the square body's (73-91 K5 Blazer) 12 bolt rear axle. Anyone done this swap before?
Swapped on early 73-87 vintage, have to measure spring perches distance. I think it is different on your 90's vintage. Other thing is get the driveshaft too. U joints bigger and check trans spline count. 14 bolts are great.
Find a 14 bolt 6 lug, you’ll thank yourself later. It’s not hard to do at all. The 14s don’t have a sway bar mount though, but I haven’t noticed any difference.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
