Any info on lifting a ‘21 with air suspension
2021z71
Seems like I can extend the leveling arms and use lower strut spacers front and back to gain 2”-3” of lift. Anyone have experience with this yet?
olyelr
Elk Rapids, MI
Seems logical. I think I would keep it at 2” or less, though. Would hate to cause damage to the bags by getting over inflated or something.
2021z71
yeah, I’d keep the bag lift to 1”-1.5”. I could go up to 2” and never use the highest lift setting, which is only available in 4wd low and I’d rarely use. It would effectively make setting 3 (of 4) equivalent to setting 4.
2021z71
Just ordered my links from John at Edgymod. If the links and lower strut spacers work, it’ll be the cheapest 3” lift ever. Fingers crossed.
olyelr
Elk Rapids, MI
Heck yea, keep us updated!
So you got spacers for the bags then? Someone already making them, or custom made?
STORMIN08
i think the thought process here is doable for the front as you are simply just relocating the strut assembly. then using the rod to tell the system where it is...
the rear on the other hand, will need an extender to give the shock the addition static length it needs to accommodate any spacer added
olyelr
Elk Rapids, MI
Then why wouldnt the front need it?
I would think at just a few inches or less, the original shocks (in there original position) should be fine. Front and rear. I mean, they will still be operating within in the factory restraints, as far as extension and compression goes...right?
2021z71
I bought the rough country lower strut spacers for magnetic ride. Haven’t tried to install them yet and not even sure if they’ll fit but all the front Silverado lifts work on 2021 Non-air Tahoe’s/Yukon’s/suburbans. I’ll have custom upper strut spacers built if the lowers don’t work. I plan to try a lower shock extender on the rear if I can find on. If not, I’ll have one made. If that doesn’t work I’ll have to do a upper strut spacer on the rear as well. Both the front and rear utilize a single shock/strut/bag unit. Fabtec is making extended rear lower arms so the cv angle isn’t to severe. They haven’t released them yet but they’ll be part of their 3” kit. Unfortunately that kit is for non-air trucks only but the arms should still work. Edgy Mod links going on in the AM.
Link to lower spacers... https://www.roughcountry.com/gmc-le...MIz-rVjLPF7gIV9T6tBh0bGwL8EAQYASABEgIGV_D_BwE
STORMIN08
you want the extender for the rear to aid in providing factory ride quality...increasing the height by pressure will drastically stiffer the over all ride
MeMo
Lake Elsinore, CA
Any updates on this?
Or anyone else lifting a 2021 Denali w/ Air
George ramos
