Any HD lower control arms for an 01?
Overlordoverland
So I had a front suspension failure the other night. Not sure if the upper ball joint caused the failure or the lower control arm..... either way the top ball joint shaft sheared and the material on the lower CA around the lower ball joint broke. Is there a company manufacturing lower CAs for these beasts?
Can you provide us with additional details of your truck (make, model, trim, etc.)? I'm assuming that your suspension is stock. If not, please provide details.
If you post the last 8 digits of your VIN, @915_Tahoe will be able to provide you with part numbers for replacement upper and lower control arms for both side, and the ball joints as well, if they are not included with the control arms.
Dantheman1540
Sugar Loaf Mountain
I have looked and looked for a nice tubular tough LCA for these trucks and have had no luck. There are a few people making uppers now but I finally just settled on MOOG Problem solver replacements.
THarber
Try dmaxstore.com. You might have to call them direct to use on a SUV but I used their arms on my old H2.
Tim
firedog9518
