AFM/DOD deleted
Swagfu
Deland, Fl
Hello all, my brother just purchased a 2008 yukon slt that has the afm/dod delete alredy completed. He was telling me that his engine light is staying on due to this. He would like it to be off. What does he need to do for this? Also, he thinks he needs a tune up as he thinks it runs a little rougher than it should. He does need to do the motor mount for sure. I told him to do the motor mount first and then see if he needs a tune up. We aren't sure how the afm delete afftects the tune of the vehicle. Is there a way to turn off the afm in the computer at home? Any advice would be greatly appreciated.
S
Swagfu
Deland, Fl
Thanks. I will let him know. I don't that he has the proper scanner for that. He may end up having to take it somewhere. i have a Ram 1500 and I have obd tool (alphaobd) that can do quite a bit of stuff at the house. I was hoping there was something like it for him.
Marky Dissod
brother just purchased a 2008 yukon slt that has the afm/dod delete already completed.
So now it's ALWAYS a V8. Excellent.
One or both of you needs to be BRIEFLY made fun of for failing to include the SPECIFIC code(s) that come with the 'engine light'.
Without the codes, the 'Check Engine' light in and of itself means one thing: GO FIND OUT WHAT THE CODES ARE.
My experienced guess: he fixed the engine (well done! literally everyone should do this), but forgot to inform the ecm of the change.
EVERYONE who disables Engine Half@$$ in the ecm, BEFORE replacing the part-time cylinder hardware with full-time cylinder hardware,
never sees these 'Check Engine' lights because the codes that WOULD apply, would have already been permanently disabled well in advance.
Go get your bro's ecm tuned to disable Engine Half@$$.
S
Swagfu
Deland, Fl
The only code he has is a P0004. I think he is going to take it somewhere local where he lives and have them do the ecm thing. Is there something he can do in the meantime, like pull a fuse or something?
j91z28d1
that's a odd code to have.. shouldn't have anything to do with afm delete.
as far as I know if you delete afm and don't turn off the code in the ecm, it runs like very very badly, like you wouldn't drive it bad.
that part was most likely done. the p0004 I'd have to look up later. Google just says fuel volume. that's a new one on me.
donjetman
usea more capable scanner that can see/read ALL the vehicle modules. Ask me how I know :)
S
Swagfu
Deland, Fl
he did end up taking somewhere yesterday and the guy scanned it for free. He said whoever did the delete did all the right things in the ecm and said the p0004 code wasn't an issue. just needed to clean some part and replace it. I can't remember what it was called. Above and to the driver side of the spare tire. Said it was pretty common. So it looks like his panic has wained now. I guess the looked at some other stuff and said everything else looked good. I think he may have found a new mechanic.
alexblagoev
