AC Pressures
Sparky75013
North Dallas
Not to offend the professional here, I used to turn wrenches back in the 80s, but am at the age where I simply do not have the patience to do it everyday. With that out of the way, my internet searches have been less than expected. The question - What are the factory specifications for Low and high side pressures of the AC system for a 2018 GMC Yukon XL SLT 5.3L? I no longer have a gauge set and am currently reading the pressures from my Autel. Back in the day, the temperature differential should be about 20 degrees cooler that the outside air temp, is this still a good rule of thumb?
Personally, I have held on to the opinion that once the seal on a system is broken, the system is NEVER the same. It never cools as well as it did from the factory, but I am open to change this opinion.
My issue is that the system does not seem to blow as cold as it once did, my Autel says the high side pressure is 263 with a range of 0-517. There is 134A in the system and want top know if a small squirt would have a negative impact. OR should I get a set of gauges and see what those readings are?
Any advice is appreciated.
SpareParts
North Idaho
Charli1964
Member Recommended
