AC cuts out under load
phatz_hatz
lawn guyland
Have a 95 TBI Tahoe, noticing ac works great at idle and under light load, once i get on it a bit the ac cuts out than blows warm. I have the coolant valve/bypass valve bypassed with a ball valve and a vacuum line off the top of the intake manifold. I’m either assuming the top of the manifold is losing vacuum and making the bypass valve open and flooding the heater core with hot coolant or the compressor is disengaging. It’s an OBD1 scan port so it’s the old fashioned one that populates errors on the dash, don’t think it’s anything to do with the PCM. Do have 33s on it so it does use full throttle i feel to get up there when getting on it at highway speeds. Any thoughts would be appreciated
phatz_hatz
phatz_hatz
lawn guyland
At full throttle, standing on it, the compressor cuts off.
I wouldn’t say I’m full throttle but i feel the tires probably make it open up more to compensate. I never tested it with the tire setup i had before which were much lighter tire set up
Rayvan
You likely have some old vacuum hoses that are loose and cracking at the fittings. Check the ones leading to the vacuum chamber (black plastic orb lookin' thing). Sometimes you can get away with just cutting off the cracked part of the hose, and pushing it back on the fitting, but you're just kicking the can down the road, so to speak. Best to just replace the vacuum hoses.
phatz_hatz
phatz_hatz
lawn guyland
Is that on the vortecs, this is a TBI. I don't recall seeing a black plastic orb thingy... I have replaced about every vacuum hose there is on this H0e. it just baffles me that I even have the controller to the coolant bypass valve and it still starts to blow hot air over 2500 rpm. I'm at a loss, the summer is over, it held a charge for 6 months so Ill likely dive into this again next year. If you have a photo of the black orb looky thing that would be much appreciated
Rayvan
I just looked it up. You're right. No Vac. Canister on the '95 5.7 Tahoes. My '94 4.3 V6 Astro did have one, I shouldn't have assumed. Still, I'd check for vacuum leaks. While it's idling, use a can of starter fluid, and spray around all of the various vacuum hose fittings. If the RPM changes, you've found a leak.
LsHart
Senior Member
No hissing in cabin? Reason for the fan question if the clutch is not engaging at temp then the condensor might be getting to hot and not getting the proper air flow to cool the freon. Go electric fans. They sell a fan kit for that.
phatz_hatz
phatz_hatz
lawn guyland
its a 5.7 TBI so the fan is belt driven, I don't believe theres a clutch on it, fan runs constantly, I may run accessory fans cause I do believe that is what is happening its not allowing the rejection of heat. But even that doesnt make sense cause when you're driving theres air constantly running through the condenser. its almost like its a phonephone. its almost like the vaccum hose I have routed to the bypass is losing vacuum, its also hard to test because it only happens when I'm driving, I've sat revving the engine with no loss of cooling steady above 2500 RPM. even with gauges hooked up no drastic difference in pressure. I am an HVAC tech by trade and it drives me insane I cant figure out what is going on
exp500
Drive it with vacuum gage attached. Under wiper works well. Then you will know. Could also run a temporary indicator lite on compressor clutch .
Manual links in Tech folder.
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
Accel and you lose vacuum and then vacuum rises as you back off accel or as you maintain higher cruising rpm.
Eman85
There's no vacum controlling anything beyond the silly water valve in the heater hoses and it really doesn't make much a difference in AC performance. It sounds like your compressor is either losing power or the clutch is slipping. At speed there should be enough air flow across the condenser to keep it cool unless there's a blockage. Can't remember if there's a spec on compressor clutch gap, Fords are notorious for clutch wear and the gap being too large, but they use a shim so adjustment is simple. I have seen weak compressor magnetic clutches.
phatz_hatz
phatz_hatz
lawn guyland
Entire system is new and installed properly, minus the EVAP core, new hoses, compressor, drier, come to think of it I haven't tested the pressure switch that's on the condenser itself. that may be the problem cause the low pressure switch I got failed within a month. All gm genuine or ACdelco, nothing is made to the same standard as it used to be
phatz_hatz
phatz_hatz
lawn guyland
so where can I connect vaccum hose to keep that valve closed from the heater core. I bypassed the solenoid it was connected to because the HVAC control wasnt sending power to it to actuate. I know the truck is old all the blend doors and things like that don't work 100% so I need that valve to be closes 24/7 when using the ac. Whole trucks a mess
OR VietVet
Willamette Valley
Sounds like it needs a vacuum accumulator of some sort. Or, some people either manually open and close it and deal with it or rig a control of some sort, from the inside, like a cable or switch or....who the hell knows.
phatz_hatz
phatz_hatz
lawn guyland
This is what I came up with a while ago. but my question is, is it possible to be losing vaccum from the intake manifold where I currently have it connected especially under a load
OR VietVet
Willamette Valley
Vacuum output drops, by itself, when accelerate and steadies as you cruise or idle. Put a vacuum gauge on there and watch the reading and then snap accel and watch the vacuum reading drop.
Fless
Moderator
People's Republic of Colorado
Is that exhaust shield made for a (missing) heat riser? Not that the air intake would need one. Just curious.
Eman85
I took the plastic heater control valve and installed it in my trash can, works just fine there. Pickups didn't have that valve and the AC worked fine. If in a hot enough climate put a ball valve in one of the heater hoses and close it in spring and open it for winter.
alexblagoev
