AC condensor removal
Blind
Can anyone give me some pointers on this? I just finished replacing the engine/trans in my truck and am now moving on to replacing all of the a/c components and I'm stuck trying to get the condenser out of the truck? I found 2 bolts on rubber mounts at the top but those rubber mounts are quite stuck to the top of the condenser...do I just need to keep prying to get those out and then I'll be able to remove the condenser via the radiator side? I removed the 2 cross bars on the backside and broke the 2 line nuts loose already.
Tbruz
Windham NH
I just finished rebuilding the ac system in my 1997 2 door(front AC only); yours may be slightly different.
Remove the turn signal lenses and remove grill
remove the top two condensor rubber mount holder bolts
Remove the top two bolts on the oil cooler
Remove the bumper filler plate( 5 screws)
Unsnap oil cooler lines from clamps beneath bumper filler plate and pull oil cooler away from condensor
remove top two bolts from hood latch upright and pull top of hood latch upright away from condensor.
disconnect 2 ac lines from condensor
You should be able to pry condensor forward and pull condensor straight up.
Tbruz
4pfTeejayiee
