grim hurst
- Joined
- Apr 4, 2018
- Posts
- 37
- Reaction score
- 69
Does your lift allow your E-brake cable to release all the way - or is it being stretched somehow.I have replaced abs speed harness twice. The abs and brake light still on. How to fix it?
Thats the first one ive checked Does the GMT800 have the harness connector on top of the frame rail, above the shock bolt area like the GMT900? If it does, it may have been knocked loose when backing out that top shock bolt.
Good thinking ill check that.Does your lift allow your E-brake cable to release all the way - or is it being stretched somehow.
Cant be the wheel hubs. Those a brand new timken; ive replaced all components during the installation of the lift kit.find someone with an appropriate scanner to scan for abs codes and it should point you in a better direction. you could have a bad wheel hub, bad speed sensor somewhere or just a bad plug or wire harness somewhere.
did the wheel hubs on my 97 brand new timkens aswell and the passenger side wheel speed sensor got warrantied by timken because it was faulty. advanced scanner pointed me right to it.Cant be the wheel hubs. Those a brand new timken; ive replaced all components during the installation of the lift kit.
