if it was from a 96 you have a serious problem. it is blinking becuase there is a problem in the passlock system if the passlock parts in the '98 were not moved over to the '96 column(never even seen that tried by the way) the system will assume an illegal vehicle start is taking place. the passlock lock cylinder will trigger the passslock sensor and if it sees a proper trigger from the lock cylinder it will pass the info the to the passlock computer and that will trigger the pcm to enable the fuel pump to run. if one part is missing it may fail-safe allow that will let in run with the light on the whole time or just fail and lock out the fuel pump. you can try the relearn procedure but all the parts must be in place. you can also visit a company with a proper tuning program to disable the system. dealer can do it to i think.
