98 Tahoe 4l60
nashranch
The other day I went to visit old friend who lives up real steep cat road 1/2 way up this hillside. I always put it in 4 wheel high . There are switch backs so you can't really go that fast. Any way was climbing and was losing power so I manually shifted it into 2nd and it wouldn't go. Felt like it was slipping so I shifted back to drive to continue on. Do I have have clutch band problems in the future. It does go ok on flat ground
strutaeng
Dallas, Texas
Umm, sounds like it could be slipping possibly? Does it do it in 2wd? What transfer case do you have? The NP246 Autotrac unit has a clutch pack that could also be slipping?
Either a transmission clutch pack and/or the band are slipping. Plan on a transmission rebuild ASAP or get it properly diagnosed...
N
nashranch
I have no idea what transfer case i have. In 2W or normal driving i don't notice any slipping . I usually just put it in overdrive and it seems fine
Fless
Super Moderator
People's Republic of Colorado
To ID the transfer case, post up the Nxx codes that are in the glovebox lid and we'll interpret. It helps to post a pic of the 4wd dash switch, too.
When was the tranny serviced last? In what condition is the tranny fluid now? Dark red, brown, smells burnt? How's the fluid level?
Eman85
First...Check the fluid level and condition. Is it still red or is it brown and stink? I've fixed a lot of transmission problems with a fuel filter.
Transfer case should have a small round plate on the back of it with a red emblem and it has the transfer case # on it. While down there check the fluid in the TC.
N
nashranch
Here are those Nxx codes you asked for... Sorry kinda sliw since knee surgery
N
nashranch
Fless
Super Moderator
NP8 is a New Process 246 2-speed transfer case. The fluid you are showing looks like transmission fluid; these transfer cases take GM Auto Trak II fluid, which is blue in color.
exp500
Any Codes set? Dash check engine light works when key turned to Run?
Also you could have been going too slow for 2nd gear.
Try hill again in 2wd, then 4low.
Trans fluid looks fine.
N
nashranch
Yes it's tranmission fluid in the picture which somebody asked for. I can't check transfer case fluid at this time due to knee surgery
N
nashranch
No codes at that time. I had shifted manually into 2 ND and it just felt like it was gonna come to a stop.
N
nashranch
Thanks for all the input... tahoe has 184,000 on it. 30,000 ago it had overhaul with new sun shell. New oil and filter.. not sure what else. Probably due for new oil and filter.
idaTAhoe
