97 Hoe factory ride height - 2wd vs. 4wd
ChrisInWI
SW Wisconsin
It seems like all the other hoes (mostly 4wd) I see ride higher than mine (2wd). I can see straight over the top of my roofline and I'm not very tall, about 5'10". All the other ones I see seem to be a couple inches taller at least. I've got factory rims and rubber right now, so that's not why I sit lower; is it just that 2wd trucks are set up lower or did the guy before me drop it somehow? I wouldn't know what a suspension mod looked like unless I saw a stock one side by side, so please talk deliberately stupid for my behalf, pics would be better! Thanks, y'all!!
TigerEyz3
Slow and Steady
TN
4wd sit 1" higher due to the "lift block" that is installed from the factory. Also, 4wd comes with a taller wheel/tire combo compared to the 2wd version: 245/75/16 vs 235/75/15, respectively (30.5" vs. 28.9").
Total height difference: ~2.5"
boble94
GM All The Way!
Lincoln, NE
245's are too small on these hoes if you ask me. so i had upgraded to some 265's.
TigerEyz3
Slow and Steady
TN
My Tahoe sits more than 2.5" lower than a factory 4wd... One of the first things I did was switch to wider/shorter tires (275/60/15) for better stability/handling. Eventually I dropped it 2"
retorq
Kingman AZ
I'm 5 10 and I can't see over the roof line of my 2 inch dropped Tahoe ... Is that the Tahoe in question in your sig??
retorq
Kingman AZ
My eyeball comes up to the top of the rear window on my Tahoe ... LOL
AtomicHoe094
Atomichoe094
cleveland, OH
What does the middle of your wheel well to the ground measure??
wait why would i measure from there?? You mean the top of the fender well and the quarter panel... because to the center of the rim, that is just the rim size and tire size, that has nothing to do with how low it is
koomie98
