2017 - didn't know the thread was for those years.
I'm still wondering how the trans temp can EVER go below the radiator temps, if it's part of that system
T-stat would run it cool until the radiator temps came up to 210, then I'd be at 210 anyways -right?
Probably best to stick with your post in the correct year, as there may be differences.
Overheating 6L80e
You're way over thinking this...Fluid is a much more efficient heat exchanger than air so by eliminating the fluid's travel through the radiator's internal transmission cooler, you've cut your cooling efficiency by at least 50% or so.... I'm hitting 230 occasionally in Florida stop and go...
