6.2 rebuild
West 1
If you know your thread pitch on the mount bolts you convert the threads per inch to determine how much movement there is with one rotation of the bolt. Then you know exactly how much you have for pre load.
These are metric bolts so a conversion may be needed unless you fully understand the metric system which I still struggle with.
C
Chris2144
This is true. And I know a lot of people use this method and honestly it all about the same as the adjustable pushrod does the same thing. I just have used the pushrod tool the whole time and don’t pay much attention to the torque spec while I’m checking.
Base circle on the cam.
Put the tool in and tighten the rocker down.
Adjust tool to zero lash then take it out and measure.
I got the engine in today, took me a little longer than it should. My ls swapped s10 got stolen recently and I had a lot of my tools in it when it happened. So I had to work with the limited tools I have left.
Sure makes me appreciate all the stuff I did have that would have made things a lot easier. Either way it’s back in now and I just need to bolt the torque converter in and put the exhaust, intake, and accessories on then fill it with fluids.
Should have it fired up at some point tomorrow. Then get a new set of tires put on it.
After all this I sure hope I’m done with repairs for a while. It’s a long list and this thing was definitely neglected for a long time.
New torque converter and transmission fluid /filter
New ball joints
New tie rod ends
New motor mounts
New air shocks/compressor
New u joints
New exhaust manifolds
Brake job
Tcase fluid changed
Diff fluids changed
And now a new engine.
donjetman
Well that is a good question. I don’t really follow that way of measuring as the ls use the pedestal style mounts anything past tight as far as ft pounds goes 22 or 100 it would be the same thing.
I used the push rod measuring tool. Installed rocker adjusted the tool to zero lash then removed the tool and measure and came up with .078.
Now that adjustable pushrod is not dead accurate as it’s kinda hard to adjust it while it’s in but it does get close enough for me to know my preload is in spec.
Of course afterwards I torqued all of them down to 22.
sad
1 turn of the rocker arm bolt = .0736"
torque a stock bolt much more than 22 ft lbs and it snaps
I don't own an adjustable pushrod. Using the method I use it isn't needed. What is needed is a way (large caliper) to measure the initial pushrods.
With the lifter on the base circle, if it takes more than 1 1/4 turn from zero lash to 22 ft Lbs? then I buy shorter, shooting for 7/8 turn give or take 1/8th of a turn.
Scrappycrow
Air Force
Alpharetta, Georgia
All you need to know for something like this is "25.4 millimeters = 1 inch." So, for example, if a metric thread pitch is 1.5 mm, divide that by 25.4 and you get 0.059" per full turn.
There are various conversion charts if that is still something you don't want to deal with.
C
Chris2144
sad
What’s sad about it? I got the measurement that was needed.
I do understand thread pitch and how many turns equals x amount. The pushrod tool does the same thing.
Of course it would strip the threads of if I tried going to much you missed the point though. Take the push rod out and then start tightening the rocker down. Once it is seated in the pedestal and the bolt is sung there will be 1/8-1/4 turn to get it to 22ft pound. In that amount of turn what is moving?
Bolt stretch
Aluminum pedestal compression
The point is from 1ft pd to 22 there is no rocker movement or at least not in the same equation as the thread pitch. So instead of that I use something solid that can be measured.
You don’t even have to have calipers the pushrod tool comes with instructions for you to do the math just like the rocker bolt method. If I didn’t have any I could still get that measurement.
Again I understand the way you are talking about to get to the measurement you need but you are using an unknown variable. Which is what is moving in that 1-22 ftpds now the good thing about it is that it is repeatable and doesn’t really change so once you have selected the correct push rod and you math comes out it will stay the same no matter how many times you do it.
C
Chris2144
Well I had a few things come up to deal with yesterday I was not able to finish up with the install but today is the day. Gonna get it fired up do a heat cycle with varying rpm’s and then go drive it.
donjetman
Bolt stretch
you really don't get it. Good luck.
j91z28d1
I must be missing something too, as I have adjustable pushrod length checkers too from other builds. I believe he's saying you snug then rocker, adjust to zero lash. measure and add the preload you want and order pushrods? you don't even need big calipers as the checker is engraved with the sizes.
how is this the wrong way to do it?
donjetman
There is more than 1 way to skin a cat.
If your happy? wonderful.
Mabe y'all can understand Richard?
Richard Holdener explains how to determine correct pushrod length on LS engines using the simple turn method without specialized tools. The process involves identifying zero lash and counting bolt rotations to ensure proper valve train function.
C
Chris2144
I understand exactly what you are talking about.
What i don’t understand is why you are so determined on this. Both ways are proven to work. I choose to use the adjustable push rod so what.
Quit talking down to people like they are stupid.
At any rate the engine is running good and will do the first oil change in the morning.
C
Chris2144
So I changed the oil and drove some more today. Everything seems good except for one thing.
Oil pressure
It’s still a little low just like before.
Cold start is fine 60+ psi
Hot idle 18-20
Hot cruise 35-38
This is with 10-40 conventional.
When I tore this engine down and saw how worn out the cam bearings looked I thought surely that’s where the oil pressure was going. But here I am with only slightly better oil pressure I had 15psi hot idle before.
Everything except the camshaft is new. It looked great so I reused it.
Spoke with the machine shop about it and they said they have had melling pumps out of the box not put out enough before and to go with the hv pump if more pressure is desired however my current numbers are not alarming and I probably am dealing with clearance stack up.
.0002 here .0002 there it adds up and leads to overall reduced oil pressure.
I could change cams and delete the vvt system all together and that would help but they said best suggestion is to put the hv pump in.
I just expected to see higher oil pressure with the new cam bearings.
All new gaskets including the vlom cover o rings.
Plug the relief valve in the pan.
New timing set with new vvt phaser.
New lifters
New rod bearings
New main bearings
.0015-.002 rods and mains
New melling pump with the medium spring in it. I have the copo Camaro spring that came with it but didn’t install it because I didn’t think I would need to.
I may drop the pan and put the copo +25 spring in to see what it does.
Other than that the engine is running great.
Going to do a compression test so I have a baseline to go off of in the future if needed.
Haven’t had any wot pulls yet but it seems very strong all the way up to 4500.
All the gen3 engines I’ve dealt with have had way better oil pressure but most of the gen4 engine seem to be lower but I still don’t like it. I may end up going with a non vvt cam and hv oil pump
West 1
Glad it is running and quiet. Nice work.
Oil pressure in aluminum block engines seems to run lower than the iron block engines. The Aluminum expands more than the steel crankshaft and steel camshaft which increases your clearances. In high end racing they build them very tight. They can't start those engines till they put hot oil and coolant in the block so it expands. Obviously we can't do that in our street driven cars but it does point out what we are dealing with.
I also think the LS style geroter oil pumps don't flow as much oil at idle as the older straight gear driven pumps.
Adding a higher pressure spring to a stock oil pump will not affect your hot idle oil pressure at all. The spring in your pump probably already has a 40 psi setting. The reason your pressure is not at 40 PSI all the time is internal leaks. Cam, Rod and Main bearings all bleed off oil pressure. The rod brg oil bleeding off does double duty as it sprays the cylinder walls with oil to lubricate your pistons.. This is all normal.
If you wish to raise hot idle oil pressure in an engine you add volume. A high volume oil pump will mask some of the leaks. Hot idle will probably jump from your 18-20 to 25-30 PSI hot idle with a high volume pump.
If you want more oil pressure say between 3,000 and 6,000 RPM you would add the high pressure spring which allows more pressure at high RPM before it opens the by pass limiting oil pressure.
BTW: my 2008 6.2L in our Denali at 148,000 miles now has 20 PSI at hot idle after I added an OIL COOLER 2 weeks ago. Formerly even at very hot idle it had at least 25 PSI before adding the new radiator and adding the oil cooler to this engine. I have 5-30W Mobile 1 full synthetic oil in it. I don't like 20 PSI hot idle so when I get bored I plan to replace my stock pump with a High Volume pump. When I first got this truck with 144,000 miles on it I pulled the pan and installed a new pick up tube Oring to clean up a small oil leak and for peace of mind. While I had the pan off I did put a stronger spring in the oil pump. That raised oil pressure at RPM but not at idle. At 3,000 RPM hot oil pressure is 50psi. At the time I was not sure I was keeping this truck so I did not install a high volume pump. My mistake. With 20 PSI hot idle you will have ZERO issues, your engine is fine. It is just comforting to look at the gauge and see strong oil pressure even at hot idle. My iron block 2003 5.3L had 40 PSI hot idle oil pressure and 60 PSI hot oil pressure at any RPM over 2,000.
GM says you don't have an issue with idle oil pressure unless it is under 10 PSI. Does not mean we like it. Some of the cylinder de activation systems will not function at less than 26 PSI so I would think GM would set the engine up to maintain at least 26 PSI Hot Idle???
j91z28d1
afm doesn't work at idle. stop start stuff is for idle mpg, afm is for hyway mpg.
and gm doesn't turn the light on till something like 6psi hot at 1000rpm. these idle like 500rpm.
its more than fine.
West 1
Donjetman you are correct for Drag Racing engines. Take a look at what they are doing in Formula One engines and Indy engines. Each type of racing has its own needs.
C
Chris2144
I think the plan is to put the melling 365hv in it. The higher volume should increase my hot idle oil pressure and then I will be happy.
After the time and money to rebuild this engine I don’t want any problems. Likley what I have now isn’t a problem but 25psi hot idle will make me feel better.
The gen3 5.3 in my s10 along with all the other gen 3 engines I’ve had have all had hot idle at 35-40. The 5.3 in my s10 has 285k miles on it. I love those engine freaking little tanks.
West 1
If you search this forum you will see that many owners of the 6.2L engines have 20 PSI hot idle oil pressure.
mikez71
Interesting.. My gen4 5.3 is 23psi at hot idle, but my gen3 6.0 is 35psi hot idle.
90k more miles on the gen4, but I guess those pressures are where they average.
donjetman
Steve Morris just got a contract to be the rebuilder of Cosworth XFE engines for a racing series.
Maybe he'll tell everyone what clearances they get built with?
alexblagoev
