So as some of you have seen in my other posts I have a 2007 Yukon with the 6.2
After buying it I went through a long list of repairs that it needed. One of which was oil consumption.
I did the top end soak thinking it had stuck rings and ended up finding out that the number 4 piston and to a lesser extent number 6 piston were coming apart.
So off to the machine shop. And now it’s back and being built.
Went .20 over. And shaved .005 off the heads. New valves, guides and springs.
Got btr ls9 gaskets supposed to be .55 thick vs stock .51 so that should almost make up for shaving the heads. Had new cam bearings installed.
All new bearings
Mains measured .002
Rods measured .003
Set ring gap at .016 top and .018 bottom.
New btr rod bolts.
New btr head bolts.
Melling high pressure oil pump with the medium spring installed.
Plugged the relief valve in the pan
New timing set.
I’ve got the bottom end together now and just waiting for the cam retainer plate to come in. I’ll be puttiing the top end together tomorrow.
New Delphi ls7 lifters
New lifter trays
Need to measure lifter preload but the math comes out right and should be right around .080-.100
All new bearings
Mains measured .002
Rods measured .003
New btr rod bolts.
New btr head bolts.
New timing set.
New lifter trays
