6.2 rebuild
Chris2144
So as the title states it’s time for a rebuild. I’ve been away for a little while life work and other things have had me busy, but before that my 07 Yukon Denali lost cylinder 4.
There was a whole laundry list of things I had done to this Yukon before this happened, but in the end I was still chasing a rough idle and low oil pressure issue along with high oil consumption.
One of the last few thing I did was a piston/ chamber cleaning to free any stuck rings and a catch can install.
Shortly after this it developed at knock/ tap sound and dead miss on cylinder 4.
I was away at work and trying to diag over the phone. I ordered lifters and gaskets because that’s what it sounded like to me over the phone. When I got home I quickly realized that was not the case as there was an extreme amount of blow by. A compression test showed about 80 psi on cylinder 4.
So I tore the head off to find the very outside of the piston above the top ring missing half way around. Cylinder 4 and 6 were like this none of the others and cylinder 6 was not as bad.
The cause of failure is unknown but to me this looks like detonation however I find it odd that we never heard knock and it’s only on two pistons. I’m still kind of torn on what to do. I really think this was a problem that the vehicle had when I bought it and I just got the tail end of it.
At any rate it will have all new gaskets when it goes back together to make sure there are no air leaks, even though I’m almost positive that was not the problem.
The block is being bored out as it had a large amount of taper. Decks surfaced heads surfaced and new cam bearing being installed. The cam bearings looked absolutely shot to the point they felt a little rough. I’m debating on installing a new cam.
Once it gets done at the machine shop I’ll be putting new pistons and rings, new main and rod bearings. New btr lifters and trays, new vvt solenoid and phaser. New timing chain and oil pump. New rockers and trunions.
New push rods.
Machine shop recommends silvolite pistons. Aside from the other parts im gonna get everything from Michigan Motorsport.
Does any one have any recommendations on particular parts or things I should do while I’m in this engine. I plan to reuse rod bolts and main bolts.
Still debating on reusing the cam. It doesn’t look to bad and if I go with a new one I’d go back with another vvt cam. It’s the wife’s vehicle and she doesn’t want anything crazy.
While you're in there, are you going to change the timing chain and gears?
Swap the plastic barbell at the rear of the motor for a billet barbell.
Also, If oil pan has a oil pressure relief valve in it, you don't need it, so put an aftermarket plug in that hole.
C
Chris2144
Yes I do plan on a new timing set.
I already got the barbell in plug kit sitting in the the parts list.
I have to look and see if a plug has been put in or not. This didn’t have afm from the factory so I don’t know if it had the relief valve I’ll double check it though
donjetman
yes it came from the factory with the relief valve in it.
C
Chris2144
I’ll have to look and see if it has been plugged or not I didn’t pay attention to it when I pulled it off.
It should definitely have better oil pressure when I’m done though those cam bearings looked horrendous
thefrey
I went in to do a DOD delete and when I got my heads off, I found my #4 cylinder like this:
Same situation as you where I have no idea how it happened. I think I caught mine early luckily because I ended up just putting a new piston in and sending it. That was at 215k miles back in December of 2025 and I now am sitting at 238k and she's still going. Not sure if it was stupid or not to just send it but it hasn't given me issues since...
I think my perceived "lifter tick" was actually the cracked ringland wiggling around in the cylinder wall, not sure since the last owner replaced the lifters before me. I bet he saw this and then decided to list it for sale lol... I never had a misfire to my knowledge and no loss of power or CELs.
I would recommend doing a new oil pump or HV pump. I put a new camshaft in and the HV pump brought my oil pressure cruising at 80mph to 40-44psi and 25 hot idle at 90F outside when it used to be high 20s cruising and 15ish hot idle.
Lots will argue that you can or can't run 87 in these motors. I however have not taken any chances with lower octanes since I saw the detonation damage. I run almost e85 exclusively now and then will blend as needed for road trips to get higher octane.
tagexpcom
Following and interested (my 2021 6.2 has 73K miles) - not picturing how an engine can keep running with pistons like this and curious to know more.
If chunks of metal came off (as apposed to malformed piston from beginning) - what happened to the 'chunks' missing from the top edge of the piston(s)? Wouldn't chunks destroy the engine bearings or something?
thefrey
Well, what should happen is that if it comes off in a chunk, it'll play a game of ping pong with the piston, cylinder head, valves, and cylinder walls and can trash all of them. Then eventually make its way out the exhaust
From what I understand, sometimes detonation can barely knock particles off and that's why sometimes there will be no damage... for instance on my engine, you could see where the aluminum had melted and then re-melted itself back onto the piston:
I don't know much how carbon deposits on pistons play into this, but I know carbon deposits do burn stupid hot, and this could be another factor of the issue and/or the issue itself.
This might be a bit of a rabbit hole, and I am not sure if this is true, but this is my thought. During AFM/DOD when your cylinders shut off, those cylinders are more prone to burning oil since oil can slip by the rings when the cylinders are off. Then they turn back on, cylinder burns oil, causes carbon buildup, then cylinder burns hotter and damage occurs... not sure if that's actually what is happening but perhaps?
Marky Dissod
During Engine Half@$$ when your cylinders shut off, those cylinders are more prone to burning oil since oil can slip by the rings when the cylinders are off.
Then they turn back on, cylinder burns oil, causes carbon buildup, then cylinder burns hotter and damage occurs ... not sure if that's actually what is happening but perhaps?
Even if no DAMAGE occurs, eventually the part-time piston rings buildup carbon, which gets in the way of ring seal weakening compression,
introduces itty bits of carbon into combustion events, score the cylinder bore walls ...
Easiest way to describe it, is the part-time V4 ages differently vs the full-time V4.
If the carbon buildup is not prevented or cleaned periodically, eventually the part-time V4 drags vs the full-time V4.
And that's if carbon buildup never causes a hotspot for detonation to take place.
West 1
The failed piston damage shown in the pictures in this post are classic detonation.
Were these factory stock or running a tune?
I repaired an Escalade, 2007 that had one broken piston. A valve seat had dropped hanging one valve open and it hit the pston and cracked the piston head. One new piston, a set of rings and 2 heads rebuilt and it ran like brand new. Good compression and less than 3% leak down. I sold it and the new owner calls me about once a year just to tell me how great it is running.
Marky Dissod
Racism against tuning, eh?
Answer to either question is USELESS without knowing
how it was tuned
how it was driven after getting tuned
Should be obvious that using 91 octane on an 87 tune, is far safer than using 87 octane on a 91 tune, for example.
Marky Dissod
I thought 07-08 6.2s didn’t have DOD/AFM?
Very early '07 L92s had ALL the Engine Half@$$ hardware, by '08 they lacked any Half@$$ hardware, but all L92s had Engine Half@$$ disabled in the GM OE software.
L9Hs lacked the hardware & had the 'feature' disabled in the GM OE software.
L94s have Engine Half@$$ hardware and have it enabled. the frey has a '13 Denali which has an L94.
donjetman
Most 2007 L92 didn't have AFM/DOD hardware from the factory, mine included. It's easy to tell by looking at the valley cover, smooth or ridges.
I believe that @Marky Dissod is correct in that 'some very early' 2007 6.2's had AFM, a very limited number, before GM decided to scrap that initiative going forward for a few years.
My 2007 6.2 did not have any AFM hardware, except for the oil pressure relief valve in the oil pan.
donjetman
The 2007 6.2L L92 actually had a first and second design.
The first design built prior to April 1, 2006 contained AFM components, but were tuned out from the ECM.
The second design (like mine and yours) eliminated the AFM components altogether except for the pressure relief valve in the pan.
C
Chris2144
Mine is an 07 and does not have did not have any afm hardware and is disabled I. The factory tune. I have run 91 since I bought it but who knows what was run before.
To me this looks like classic detonation but I find it odd that it is only on 4 and 6.
I have no afm so I know that doesn’t come into play on mine. Maybe a prior intake leak leak caused a lean condition that was localized to 4and 6. Who knows.
Thefrey has the exact same piston failure as I have. I contemplated putting 2 new pistons running a ball home through it and sending it but this is the wife’s car and I figured I’d just do a full refresh.
New cam bearings
New rod and main bearings
New btr lifters
New Michigan motorsports rocker trunions
New oil pump
New timing set
New vvt actuator
New pistons
Machine shop said the block needs to be bored slightly to correct some taper.
Surface the heads
New gaskets
Hopefully after all this I won’t have to worry about it anymore.
Still bugs me that I don’t know why it happened other than it was a detonation issue.
Marky Dissod
Far more likely than you realize. Intake gaskets should be considered service items that will eventually need replacing,
the question is the service interval.
C
Chris2144
Well the intake gaskets were just replaced along with the vlom rear main and valve cover but regardless it will get all new gaskets and I will be checking plugs to verify.
Fuel trims were off but it had a leaking exhaust manifold and after I fixed that fuel trims were very close from one bank to another and they were low I think like 1.8-2.1 if I recall correctly.
In all of this the cylinder walls still looked great and if not for the taper it would have just had a light hone and be done I was shocked I thought it would have definitely torn a cylinder up.
alexblagoev
