6.0 in a 1500
Drew1987
Hey all
Just want to confirm if I take an L96 6.0 from, say, a 2011 2500hd pickup, and move over our 5.3 accessories and oil pan, toss it in place of the 5.3, just update the displacement in hptuner (DOD is already disabled), it runs with the factory ecu?
Bolt in swap as long as I move over the whole belt drive and accessories and oil pan?
Thanks
SpareParts
North Idaho
Not me but,
Sounds like it would work.
I have only been swapping around 6.2s as far as i can remember.
Drew1987
Drew1987
Wife’s burb is a 13. Yes the mechanical part is silly simple, it’s just all my research says you literally can go into the system and change the displacement to 6.0 and it will run everything as long as the deactivation lifters are turned off (which they are)
Her motor has been making a little noise, and I have no problem slapping a good used engine in it, but for an extra thousand bucks or so, a 6 L would be wonderful in the mountains. We are a big family and we always have a lot of stuff, she often grabs a little trailer etc., and I could absolutely justify 6.0
My research says it’s easy Peezy, but I would love to hear from someone that does it and can confirm that it is lemon squeezy.
If not, maybe some better cam and lifters for the new 5.3
j91z28d1
if you get the 6.0 with the rectangular port heads., I'd probably copy over the timing tables, and the timing retard stuff.
Drew1987
Drew1987
Yea the goal would be it functioning as stock -didn’t know about different head ports thanks - I’ll have to be aware of that
The goal is to drop in a 6.0 and keep it as “stock” as possible… If it’s more than just moving over the pan and the accessories and editing the CPU accordingly, I would just improve a5.3
j91z28d1
I don't know the details off the top of my head. but yes, ls engine use two different head designs. the 6.0 is the split. they have different engine codes that use both low end tq hesd like your 5.3 and bigger port higher end hp head the 6.2L use.
Drew1987
Drew1987
Thanks for that - I’ll dig into it
I am fairly certain the 5.3’s exhaust manifolds need to go on the 6.0, but I think the 6.0’s intake needs to remain on it so the former is what I’d be after
j91z28d1
I pretty sure all the exhaust manifolds fit any ls. I've even put ls7 D port exhaust manifolds in a round exhaust port ls3 and it's fine. you'll be fine there.
intake will match the hesd but that shouldn't be very hard either as both both styles came in trucks.
Drew1987
Drew1987
Super helpful thanks!
Just trying to get ahead of everything so I don’t turn my wife’s family vehicle into a “long-term project”
Fless
Moderator
People's Republic of Colorado
They would appear to use the same exhaust manifolds:
Marky Dissod
Just want to confirm if I take an L96 6.0L from, say, a 2011 2500hd pickup, and move over our 5.3L accessories and oil pan, toss it in place of the 5.3L,
just update the displacement in hptuner ...
Feel free to use any L76 / LY6 / L96 / LC8. I'd only 'move over' any stuff that is NOT specific to the 6.0L. If it's '6.0L only', I'd keep it on the 6.0L.
By now you know it's more involved than 'mo qyoobz', but it's not that complicated, several 6.0L-specific tables and figures and stuff.
Bonus points if the 6.0L is an L76 / L77 from a CAR vs a truck, those are a lil bit more fun in GM OE spec vs the 'truck' L76/LY6/L96/LC8,
but those will need a few more truck-specific parts, so it might not be worth it to you.
Drew1987
Drew1987
Thank you for that!
The goal is the absolute simplest swap. I’d like to do it just before I have to do it kind of thing, but if I’m pulling the motor out of this truck, replacing it with a heavier duty, more powerful option just feels right
As I mentioned above we live in the Georgia mountains, and we are always loaded down
I used to see GMT 900 2500 suburbans all the time at auction, I haven’t seen one in months, if it all in 2026. That would be the perfect truck for her. But we have this one. It’s paid for
strutaeng
Dallas, Texas
L96 was made up to 2020 on the 2500/3500 Express vans.
We have a 2020 3500 Express van as a family hauler with the L96. Just make sure you are swapping an LY6/L96 which are Gen IV engines with rectangular port heads.
Not Gen III engines because the reductor wheel count and timing gear count are different, besides the rec. port heads vs cathedral ports.
Drew1987
Drew1987
Alright so pretty much the 900’s and the trucks right after - before that was 800’s no good and of course after that is the 6.6. That leaves a lot of donors!!
I’d still love to hear from someone who did it to know for sure it’s just a matter of moving the belt drive/pan and changing a few things in the ECU - the big thing is it’s not a toy or a “build” it’s how my wife gets around all week
I have no direct experience with the 6.0 motor, but I did take a quick look at the differences between the 6.0 motor for a car and a 6.0 motor for a truck.
The GM L76 6.0L Gen IV small-block engine was produced in both car and truck configurations, featuring notable differences in intake manifolds, variable valve timing, and accessory drives.
GM L76 Car vs. Truck Differences
    • Intake Manifold: The Pontiac G8 GT car version uses a lower-profile car-style intake manifold, whereas the truck version (found in 2007–2009 Chevy/GMC trucks and SUVs) features a longer-runner composite intake designed to build low-end torque.
    • Variable Valve Timing (VVT): The L76 truck engine came equipped with VVT and a cam phaser, while the passenger car variant (like in the G8 GT) did not feature VVT.
    • Accessory Drive & Oil Pan: The truck version uses a truck-specific accessory drive spacing (brackets, alternator, power steering pump layout) and a deeper oil pan designed for full-size engine bays, requiring a swap if placed into a car chassis.
    • Power Ratings: The L76 truck engine was factory-rated at 376 horsepower and 375 lb-ft of torque on regular 87-octane fuel, slightly edging out the car version's advertised rating due to the torque-optimizing long-runner intake manifold.
Drew1987
Drew1987
Super helpful thank you, not to worry I will be going for a truck engine… Not looking for performance or horsepower or anything like that, a bone stock 6.0 is a decent enough upgrade over a 5.3.
The thought process is the same if it was 1970 and I was fixing my 1957 Bel-Air… I’m yanking out a 283, why not drop in a 327?
We don’t drive fast, and when towing, we do so gently, but that 5.3 just does not consistently feel like enough with all of our kids all of our stuff and a small trailer in the mountains with the air-conditioning on
mikez71
@DaveO9 had the last thread about a 5.3->6.0.
Chevy1234
