5 channel amp with stock head unit
redemn93
Jupiter, Fl
forgive my ignorance but is there some kind of converter box i can use with the stock head unit to send the signal to a 5 channel amp?
i am thinking about this set up.
JL 500/5
some kind of good speaker in the doors
CVT 8" in stock box
i was going to mount the amp under the back seat.
i think it would make a nice complete sounding system, no?
and i would like to keep the foward firing tweeter that are in the rear pillars. how to make this all possible using the stock head unit?
NathanJax
Vacation Nathan
Jax, Fl
JL Clean Sweep
R
redemn93
Jupiter, Fl
ya right after i made the post i discovered line out converters.
would it be possible to use multiple line out converters? like one 4 channel for the doors and one 2 channel for the woofer?
blueflamed03
Oklahoma
yes, a $25 LOC (line out converter) from any dealer...and I would opt for a 5 channel, less power wire, RCA, runs to make...unless you really want two seperate amps?
I soon plan to add a Kicker ZX7005 and QS652 in front, QS60 in rear door, and a single sealed 12" in rear. Keeping stock HU for now.
R
redemn93
Jupiter, Fl
i plan on doing one amp and keeping the stock head unit. i have been looking and cant find a 5 channel LOC. cant find one. not even the crutchfield guy had heard of one. do you know where i can find one? front channels, rear channels and a SW channel.
the more i think about it the more i dont want to do it until i can afford to buy the dynamat as well. almost all the panels will have to come out. only thing more to do for dynomat is seats and carpet (the easy part). agh...decisions
MOBmentality
Has a $25,000 Punch
there is no part of that system i would sweat dynomat on.. the mat will reduce road noise more than help with that system.. I have a total of 4 kenwoods on a 400.4 and 3 jl 12s in a sealed box with 1000ws and there isnt a single vibration noise on it
ROBERTOcritser
Kentucky
I think you should atleast do dynamat in your front 2 doors cuz Ive started to notice a lot of rattling sounds in my door panel. Thats what I plan on doing when I put my high's in.
BTW Im putting JL C2 6.5's in the front and then just clippin the power to the stock tweeters. and gettin somethin else to go in the back doors eventually. prolly somethin that will run off my deck for now cuz I really dont care what it sounds like in the back. That will just be filling noise.
groundscr8pr
flaccid member
scarborough maine
u do not need a loc on jl / series amps. they have a balanced line in and a high/low input switch. all you will need is rca cables. run a front set and a rear set. at the back of the deck cut off the rca ends. wire the center conductor of each rca to the + speaker wire and wire the rca shield to the speaker -. then set the input switches to high. you can also set up the amp to take signal for the sub channel from the front and rear ins so will not need a signal cable for the sub.
R
redemn93
Jupiter, Fl
if i do that with the RCAs i will get no mids right from the door speakers right?
i guess i will see on the amp to get the signal front the front 2 to get the sub signal?
if i leave the wires for the rear tweeters at the hatch they will still function?
robert, are you doing the C2 components or coaxials? i see both.
MOBmentality
Has a $25,000 Punch
It means voltage..(on the input side) meaning its a pre amped signal.. as opposed to the un amped signal coming from the rear rca outputs on an aftermarket
So it wont affect the ability to produce highs and mids.
(or am i wrong)
groundscr8pr
flaccid member
scarborough maine
(or am i wrong)
you are right. the amp will take signal from the pre amp in and use it to provide signal to the sub channel. the crossovers on the amp are further down the signal chain. you will want to set channels 1 2 3 4 for high pass for your front and rear speakers. then set your sub channel for low pass. if you go to jls site and check the tutorials section there is some really good info on setup and tuning.
RobK
