4L60E Input shaft differences
Matthew Jeschke
Sahuarita, Arizona
I discovered my transmission broke the forward overrun due to a cross leak between forward and overrun clutch on the input shaft. I'm going through my parts and I have two possibly three subtly different input shafts. They are dimensionally equivalent. Anybody know what the story is behind this? If one shaft is better than the other or if they're all equivalent. The shaft on the left which was in my truck / the trans I built, isn't coated. note I've already pressed it out of the drum. The middle shaft is coated but a dull finish. The right shaft is from the original 2001 transmission in my truck. It's appears to be the best astetically.
What is this coating about... Did somebody just remove it from the left shaft?
Maybe interesting to see, the middle drum is SHOT, I got the core from a guy who put the 4L60E build behind a 383 stroker on his square body. Cool truck but the person who built it didn't do much. Metal check balls were hammered into the plate. Packs had new and old frictions in them (probably okay?) The 3-4 clutch pack splines were TOTALLY chewed up. He ground down steels to clean them up... The planets were all loose (I had to throw them away). I think the guy must have stood on the gas as soon as it started slipping because the gaskets were burnt to the case and the valve body. The whole thing was a complete mess.
PS... I don't think there's many transmission builders on this forum, although I really enjoy posting here cause you're all quite cordial and nice. I've tried some of the forums where more of the transmission builders post with not so great results.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
I appreciate you sharing. I wish I had an answer. I really want to learn more about transmission rebuilding. My poor Yukon is still sitting in the garage with a broken transmission, many months later.
Where do you live? If you are near Tucson I'd be happy to help you build one. Could probably walk you through the whole process regardless.
Sam Harris
Texas
I’m in east Texas, so pretty far away. I might need your help though, and would be very grateful if you would be willing. I’m sure I’ll need to buy some tools I don’t have as well. My biggest issue at the moment is, coming up with a good table / work platform to work on it. I have pretty severe back issues, so have to be careful about making sure I’ve got things at the right height, and not bending down too much etc..
NickTransmissions
Sin City
The transmission bench
That first shaft with no coating is a factory shaft but may be a mid-2006 shaft cast with the TSS feed hole pattern which displaces the holes about a half inch or so compared to the non-TSS shafts however those particular shafts did not actually have the TSS reluctor gear cast into them.
You or anyone will want to be careful about mixing a TSS shaft (or a shaft like the uncoated shaft may be) with a pump stator not designed for use with the TSS input shafts. Mixing them together may lead to premature trans failure.
My video on forward drum / input shaft changes explains in more detail.
700R4 & 4L60E Forward Drum Changes and Interchange Information 1982-2013
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
@NickTransmissions thanks! Been watching a ton of your videos. I owe you one for all the help.
I am flying to Austin to help fix up a Honda. Last year was in San Antonio to rebuild a Jeep. Both for same friend he flys me out when he has major projects on his vehicles.
There aren't too many speciality tools, although I just bought a press which is a good thing to have access to. The tools that are needed are fairly cheap.
Sam Harris
Texas
Good to hear! I do have a press, so that will be helpful.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
It's a really fun process IMO, aside from pulling the transmission which I dread. I'd take a different approach. Build it then find a shop that'll swap it out for you.
Buy a buildable core, if you can find one. Otherwise, buy a core (somebody broke), off craigslist, facebook marketplace, or wherever locally. I think you want a 2005 case or older but no older than (~1999?). The rollerized reaction shaft is in there somewhere (after 2002?) which is preferable if possible. I don't think you have a input shaft speed sensor (I think those are only on newer controllers that were not on the GMT800). Sort some of those details out. PM me if you need.
Get the latest edition of the 4L60E ATSG manual.
Bookmark Nick's channel if you haven't already https://www.youtube.com/@nickstransmissions/videos
Bookmark the Transmission Bench 4L60E Rebuild Guide:
Nick shows how to fix issues like a leaky input shaft seal that aren't covered in the Transmission bench tutorials. He also has some great tips to build a better than OE transmission and he's great at answering questions on his YouTube.
Otherwise, @NickTransmissions do you do freight shipping?
If not, I'm friends with a builder in Tennessee. He's been mentoring me on tuning, and transmission building. He's very good. Depending on where you're at it maybe a long days drive but worth it. These transmissions are fairly light and can fit in the trunk of a car. He mostly only helps local people but I can ask him if he'd not mind helping you.
I also have a converter shop here that can custom build you a converter for a fraction the cost of aftermarket. They ship them all over the country. I paid $650 for one form CircleD years ago. Now they're better part of $1000. He builds a better one for under $400... And they've build thousands of converters.
NickTransmissions
Sin City
I dread pulling the transmission. building part is fun though IMO. Nick's YouTube runs through most (all?) the steps to build one. Certainly the ones for a high quality build / upgrades. If he can ship a trans prob your best option. An ATSG manual helps a great deal too.
If you need to have a step by step, then follow the transmission bench 4L60E tutorials. They cover every single step on a step by step basis.
When I did mine I bought a core off craigslist, built it and swapped it on.
Thank you for watching, Matthew.
For anyone else reading this: My video series is much more extensive, detailed and comprehensive than anything Transmission Bench puts out. I show assembly (all steps) plus clearance measurements/adjustments for clutch packs, end play and vacuum testing. TB doesn’t come close (plus gives bad advice in a few places, IMO).
Here’s my full playlist for the Level 1.5 4L60E build; it also includes my 4L60E Special Tools video:
4L60E Level 1.5 Full Rebuild
Sam Harris
Texas
Thanks so much! I have this “level 3” Performabuilt, that had a failure, and would like to ensure it is as strong as possible. I don’t have a whole lot of extra hp, but a little, with heads, cam, tune, etc.. so fairly significant I suppose over stock. Would the 1.5 build series be sufficient? I’m not sure what parts would be best for replacement in the Performabuilt transmission, but still need to figure out what went wrong as well. (Loud pop, lost all forward gears, but reverse works) Performabuilt thought it might be a sprag.
NickTransmissions
Sin City
You’re quite welcome, Matthew.
I do have customers who ship me their transmissions from all over the country so it that’s something you’d like to explore, let me know and I’ll send you a PM.
Please note that I am not taking on any new work until October so totally if that is to long of a wait.
goldpack
picking this thread up late,
but I notice when I am hunting 4L60E transmissions on car-part.com
the selector puts SUV type:
trailblazer,tahoe,suburban,avalanche...and their GMC variieties in one lot
and their pickup truck selection in another lot.
not completely sure: shaft shape/ pan shape, mounting holes.
so one "may" need to swap parts side by side if mixing. (like pulling things off the existing to put on the donor,...so important to pull if returning as a core anywhere).
@NickTransmissions can you shed some light on why, or is it even true.
(like is it easy to drag and drop a 2002 4L60E from a 1500 pickup 5.3, into a 2002 tahoe with the same specs, ...any differences ?)
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Which transmission rebuilders (in the Tucson area) do you recommend?
I can help if you're wanting someone local. I'm in Sahuarita, a few minutes south of Tucson.
Those vehicles have the same transmission. There's some small variances between years, but otherwise a 4L60E is in most all of those. If swapping between GMT800 chassis and say 1/2 ton you should be fine. The only exceptions I know off myself are 3/4 ton chassis, and SS trim packages.
@NickTransmissions would know more...
Yes the list above all use the same pan (there's a deep and a shallow pan, deep is for tucks). What years and models are you trying to compare?
I see you're question was directed at Nick but maybe I can be of some assistance.
They should be interchangeable. So long as they are both 4L60E (they should be) and both the same in terms of 2wd or 4wd. If you get too old of a core... (pre 98?) the torque converter was different so you have to be careful about that. Too new and they harness is different (post 2006???). The GMT800 stuff (3rd gen Chevy small block / LS) they are pretty well interchangable.
strutaeng
Dallas, Texas
ANY GMT800 4L60e pickup or full size SUV will work (Yukon, Tahoe, Suburban, Avalanche, H2 Hummer). My 1999 Silverado 4.3 4L60e had the "LS" bellhousing bolt (empty, of course) and the 300 mm input shaft. So I believe GM made ALL the 4L60e the same, regardless of V6 vs V8 on this generation.
AVOID anything GMT400 4L60e what has the wrong bellhoising mated to a SBC, and they had differences in the V6 and V8 varying input shafts, torque converter, clutchpacks counts, and whatever they were toying around with back then. That includes mid-size SUVs, S10s, Blazers, and Express vans.
I suspect you can use 2003+ Express vans 4L60e since those were all LS powered. Confirm yourself.
1997+ 5.7 LS1 powered cars may be the only exception (but NOT the Corvette), but those are so rare nowadays you don't have to worry about these.
...basically, stick with any pickup truck or full size SUV GMT800 4L60e is the easiest way to remember...
alexblagoev
