315s on my hoe
Dahoe06
North Carolina
Im planning on putting 315/70r17s on my 06 tahoe z71. Everything is stock on it but Im also planning on getting a six inch lift. Is there anything else I would need like spacers or anything?
Big Mama
Virginia
On stock wheels? Go to the tire size calculator on line and see how much wider and taller they are vs your current set up and see how far you’d have to go up to clear everything. Lots of us run 305’s but shorter sidewall like 40.
I'm thinking that a 315 tire width may be too wide for a stock rim width, at least as per the tire manufacturer's specifications. When I installed my 305/50x20 Michelin Defenders on my stock 20 x 8.5 rims, Michelin stated that that was the widest tire that they would specify for an 8.5 rim width.
Perhaps, other tire manufacturers have different specifications for minimum rim widths for 315 tires. I recommend that you research this a bit (in addition to discussing it on the Forum), just to be sure.
Dahoe06
Dahoe06
North Carolina
I won’t be using the stock wheels, my brother has 16x8-12 offset rims he’s gonna sell to me so those are the ones I’ll be using
AlejandroDinero
Destin
What modifications have you done to this to make those 315s fit?
sorry took me forever to reply, never got a notification. only thing is slightly trimmed plastic thats it with a crank. i have some 2 inch rear spacers but havent installed them. going a different route
Mistehkins
