2026 Yukon Metallic Squeak/Rattle from Second or Third Row
tjonesdfw
Our 2026 Yukon AT4 with center row buckets has a metallic squeak/rattle that is almost constant with any road vibration. I know sounds can be elusive, but to my ear from the driver seat appears to be coming from the second or third row. Haven't tested it each each respective seat occupied, but with the front and middle two occupied, you can still hear it. Has anyone here experienced this and found a fix? Dealer keeps claiming they can't replicate so headed to drive it with them next week.
2024 White Tahoe
Although this TSB applies to 2025 and earlier models, it may have been updated to include the 2026 models: https://static.nhtsa.gov/odi/tsbs/2025/MC-11019377-0001.pdf
You may want to print it and show it to your dealer?
Badmunky
My 2021 is doing the same thing.
Its driving me NUTS!!!!!
I have not looked for it yet, but will here shortly.
genestoy
Arizona
Not quite the same but my 26 Yukon At4 has done a loud pop/bang as if I ran over something and it hit the floorboard underneath the rear drivers side captains chair. I have done some internet research on this and it appears it could be one of a couple of things, some suggesting it is the seat itself shifting, some say it could be the baffle shifting in the fuel tank, who knows. It has only happened about three times on our recent 4000 mile trip, but it sure is loud and scary when it happens and no I have not run over anything!
T
tjonesdfw
After nearly a week in the shop, our dealer claims to have found the culprit. Apparently there is a piece of foam insulation inside/behind the rear quarter panel that was left out when our MY26 AT4 was built. They think it was allowing something in that cavity to rub and create the buzzing noise. It's unbelievable that a modern vehicle can be delivered missing parts! I'll report back more when I get it back for others that may be dealing with the same issue.
T
tjonesdfw
Unfortunately the dealer didn’t provide much detail on my invoice regarding which parts were replaced, but the noise is gone for now so thankful for that!
T
tjonesdfw
…day 2 post repair and the noise is back worse than before. Videoed it this time and took it right back to the dealer. :rolleyes:
gobigred79
I have a 2026 Tahoe RST with 6k miles and has the same issue. Started about a month ago. I have not had time to take it in yet. Following to see if you get any resolution.
T
tjonesdfw
I haven't picked up the truck to verify if this fixed the noise yet, but apparently the riser bracket for the third row seat was bent or loose and they had to replace that this time. Wondering if they had to remove part of the third row when they replaced the missing insulation pieces in the rear quarter panel last week and then damaged or didn't get something re-installed right.
I'll report back with any details from the paperwork and whether this resolves the noise from the rear.
Mariam26A
