2024 GMC Yukon XL Denali Ultimate
Billy Buzzard
I just had winter tires installed. Max Speed is now limited to 56 MPH. Suspension leveling is flagged as requiring service.(4 corner Air suspension), All tires flagged as requiring air-just pressured to 50 PSI.
Any suggestions to save me a long trip to the dealer?
Thanks
2024 White Tahoe
Thanks
Did you use the same size winter tire (and wheels) as the OEM size tire?
I cannot personally help you, as I am not that familiar with your model year.
But, I asked Grok, using your own words, and this is the reply.
The speed limit to ~56 MPH combined with the “suspension leveling requires service” (or similar “Service Leveling System” / “Service Air Suspension”) message is a known protective response on 2021+ GMC Yukons/Yukon XLs (and related Tahoe/Suburban/Escalade) equipped with the four-corner Air Ride Adaptive Suspension (RPO F47). The vehicle limits speed when it detects a fault in the air suspension system. The tire pressure flags are very likely a separate but concurrent TPMS issue triggered by the wheel/tire swap.
Why this happened right after winter tires​
  • The shop almost certainly raised the vehicle on a hoist or floor jack. On these trucks, that automatically enables Service Mode, which disables all air suspension operation (raising/lowering and compressor). Service Mode is supposed to exit automatically once vehicle speed exceeds ~10 mph (16 km/h), or you can manually disable it in the settings. If it did not exit cleanly, or if height sensors, air lines, or fittings were disturbed, the system can set a fault and trigger the service message + speed limiter.
  • Air-line fittings not fully seated (a known issue on these platforms) can cause under- or over-inflation of one or more air springs, leading to lean/sag and the exact messages you’re seeing (including speed limited).
  • TPMS: Winter wheels/tires (even same size) require a sensor relearn so the vehicle knows the new sensor IDs and positions. If the shop transferred the original sensors or installed a second set without completing the relearn, all four corners can show as needing air (or the system shows a fault). Cold weather + any pressure drop during the swap makes this more likely. 50 PSI is almost certainly higher than the door-jamb placard value (typically in the mid-to-high 30s PSI cold for these vehicles—use the placard, not the tire sidewall max).
The winter tires being the same size is good; that rules out a pure size/calibration mismatch.
What to try first (in order)​
  1. Confirm and correct tire pressures
    Set all four tires (cold) exactly to the pressures on the driver’s door placard. Do not use 50 PSI unless that is what the placard actually says. Drive a short distance and see if the pressure warnings clear or change.
  2. Exit Suspension Service Mode
    • In the infotainment screen go to Settings → Vehicle → Suspension and turn Service Mode off if it is on.
    • Drive above 10–16 mph.
      Many owners report the message and limiter clear once Service Mode fully exits.
  3. Perform a TPMS relearn (required after any wheel/tire swap on these trucks)
    For 2021+ Yukons the typical stationary procedure is:
    • Inflate to placard pressures.
    • Parking brake on, ignition ON (engine off).
    • Use the DIC/steering-wheel controls to reach the tire pressure screen and hold the checkmark until the horn chirps and it says “Tire Learning Active.”
    • Starting at left-front, use a TPMS activation tool (or a strong magnet in some cases) against the sidewall near the valve stem until the horn chirps, then move clockwise (LF → RF → RR → LR).
    • Two horn chirps at the end confirm success.
      Some 2021+ models also support an auto-relearn by driving after pressures are correct. If you don’t have a trigger tool, many tire shops will do the relearn for free or low cost.
  4. Basic visual/ride-height check
    Park on level ground and look for obvious lean or one corner sitting differently. Listen for the compressor running excessively. If the vehicle looks level and Service Mode is off but the message remains, stop and go to a dealer—do not keep driving hard with the limiter active.
If the above does not clear it​
Take it to a GMC dealer (or a shop with GDS2) promptly. They will:
  • Pull DTCs (common ones are in the C118x / C119x range related to height sensors, air springs, or compressor).
  • Check air-line fittings at the springs, manifold, and reservoir for full seating.
  • Inspect height sensors and linkages.
  • Perform a Trim Height Learn / calibration if needed.
  • Verify no air leaks developed during the tire work.
These systems are sensitive; a simple hoist-related Service Mode hang or a slightly disturbed fitting is a frequent real-world cause right after tire service. The tire-pressure flags should resolve with correct pressures + relearn. Once the suspension fault is cleared, the 56 MPH limit should disappear.
jfoj
Did you have the tires replaced on the "original" wheels, or do you have an extra set of wheels with Winter tires?
If you have a 2nd set of wheels and tires, do they have the correct TPMS sensors or TPMS sensors installed at all?
There are 2 different frequency TPMS sensors, 315 MHz and 433 MHz. If you used an other set or a used set of "Winter" wheels and tires and they had TPMS sensors then the frequency may be wrong and/or the batteries may also be weak/dead. TPMS sensors need to be replaced typically every 8-10 years.
The tire pressure you are currently running of 50 PSI is very high. I believe the standard pressure should be around 36 PSI in these trucks? First thing I would do is set the tire pressure to the door placard value.
Then the next thing is to relearn all the TPMS sensors to the vehicle, assuming your current wheels have TMPS sensors, if no TPMS sensors, you WILL need to get sensors installed.
The tire shop should have a tool and they should be able to easily determine if they are 315 MHz or 433 MHz sensors, if they work/have a battery strong enough to transmit.
You could also buy a tool like this for around $15 from Amazon and try to program/relearn the sensors to the vehicle. I believe you can put the vehicle in TPMS learn mode from the DIC (Drive Information Center) search online and/or read in the owners manual.
Cheap TPMS Tool
The problem with the cheap tool it is will only trigger the sensor, it will not tell you what frequency, show the tire pressure or even show if the sensor did not transmit. Some sensors even report the battery condition as well, but not all of them support this feature.
As for the Air Ride, assume once the TPMS system is working, the Air Ride should correct itself unless the shop damaged something with the vehicle up in the air. For future tire swaps I would consider just jacking up one wheel at a time from under the control arm and change one wheel at a time.
Charli1964
