2023 - 2024 z71 Search
t_bergman
Chicago
After way too much research, the decision is finally made. I'm going to start looking for a 2023–2024 Tahoe Z71 in the next few months, and I'd like to hear from the people who have actually owned and driven these years.
Some of you may know me from the older GMT800/GMT900 sections, I'm probably best known around here for the GMT900 dashboard replacement. I couldn't convince my wife she wanted a 2500.
The target configuration is:
- 2023 or 2024 Tahoe Z71
- Sage Green Metallic
- 5.3L L84
- 4WD
- Max Trailering Package
- eLSD
- Captain's chairs
- No rear-seat entertainment
- Prefer Magnetic Ride Control
- Under ~35,000 miles ideally, although I would go higher for the right truck with excellent history
This will primarily be my wife's daily driver/family vehicle. She is coming from a Wrangler 4xe, looked at the 4Runner, Land Cruiser, Bronco, and GX550. She's a bit mad that I was right and that she ended on the Tahoe.
One of the first changes will likely be tires. The factory tires will probably come off fairly quickly in favor of Michelin Defender LTX/AT2s.
5.3L / build-date question
I have access to GM service history through a Cadillac service manager, so I'll be checking VINs before purchasing.
There are also certain engine/build-date ranges associated with the known lifter issues that I intend to avoid where possible. If anyone has a good current reference for exactly which 2023–2024 engine build dates deserve extra scrutiny, I'd appreciate it.
What I really want to know from owners
At this point I'm less interested in whether people like the Tahoe and more interested in what starts showing wear between 20,000 and 75,000 miles.
For those of you with 2021+ Tahoes/Yukons, especially 2023–2024 Z71s:
What has actually failed or started wearing prematurely?
I'm thinking things like:
- MagneRide shocks/struts
- suspension bushings or ball joints
- wheel bearings
- CV axles
- eLSD issues
- transfer-case issues
- 10-speed transmission behavior
- cooling-system leaks
- engine mounts
- exhaust issues
- electronics/modules
- infotainment problems
- cameras/sensors
- power running boards, if equipped
- HVAC problems
- interior rattles
- seat wear
- weatherstripping/wind noise
- tailgate hardware
- anything else that tends to show up once these get some miles on them
I'm particularly interested in the items where an experienced owner would say:
"When you're looking at one, check this."
eLSD / Z71 owners
I'd also really like feedback from people who specifically have the eLSD. Has it been reliable? While GM claims it's better, I can't see it really being better than my G80 in the 2500.
Anything I should listen or look for during a test drive?
Any fluid-service recommendations beyond GM's normal schedule?
There are some older discussions here suggesting differences in how the eLSD behaved between the early 2021 trucks and later 2022/2023 trucks, so I'm especially interested in long-term experience rather than just whether it works off-road.
MagneRide
For those with MagneRide but without Air Ride, how has it held up as mileage accumulates?
I'm comfortable replacing shocks when they're eventually worn out, but I'd like to know whether there are common failures, sensors, wiring, modules, etc. that I should specifically inspect.
What would make you walk away?
This is probably my biggest question.
Assume you're looking at a clean 2023–2024 Z71 with 25–40k miles.
What would you see during an inspection/test drive that would make you immediately move on to the next truck?
Conversely, are there things people worry about on these trucks that really aren't a big deal?
I'd especially appreciate input from owners who have 50k+ miles, tow regularly, live in the salt belt, or have had these trucks apart themselves.
What should be on my inspection checklist?
Pic of the 2500 for attention.
JKeller
My 2021 Tahoe HC was still running great when I traded it in at 150k miles (6.2L). The only early wear I saw was with my differential - it started groaning during turns around 50k miles. I found a video that recommended a fluid change with 2 supplements, which I did every 30k miles thereafter and the differential never made a sound again. Two friends also have 2021s (one has a Tahoe and another has a Suburban). Both of these vehicles had the same issue and the fix worked on both of them too.
The Magnaride shocks lasted fine (75k miles) but when they went bad, the "clunk" on bumps was a lot more noticeable to me than prior vehicles without Magnaride.
Overall the 2021 Tahoe was a great vehicle. I think the truth is, most are great vehicles, regardless of the year. I've had a 2003, 2007, 2015, 2021, and now a 2026. Interestingly, the only one that had engine issues was the 2003: a lifter went bad and ate into the camshaft. It resulted in a rocker "tick" with no other symptoms (i.e., it drove fine). I put another 5.3 in a junkyard in that 2003 and drove it until about 200k miles.
- 5.3L L84
- 4WD
- eLSD
- Captain's chairs
- wheel bearings
- CV axles
- eLSD issues
- engine mounts
- exhaust issues
- cameras/sensors
- HVAC problems
- interior rattles
- seat wear
- tailgate hardware
eLSD / Z71 owners
MagneRide
“…The factory tires will probably come off fairly quickly…”
If the tires on the 2023 or 2024 are anything like those on the 2021 and 2022 Tahoe Z71s, they will probably be ready for replacement by 35,000 miles anyway.
The tires on my 2022 Tahoe Z71 had the shortest life of any OEM tires I have had to deal with. A relative experienced similar tire life on his 2021 Tahoe Z71.
Regarding inspection, test the spare tire hoist to ensure it actually works While the tire is lowered check for rust in the space that surrounds the tire. I recently saw more rust in that area than I would have expected after 4 years and about 100k miles.
BacDoc
Vero Beach Florida
I have a 2024 Tahoe HC with the 6.2l and have around 20k miles but tow a ~6k lb boat/trailer a lot.
Also mostly short trips and spirited driving when possible so I am actually “severe use” even though low miles.
Even though I don’t have the 5.3l I think I can comment as I have friends who have both gas motors and put lots of miles on those model years, interesting that the only engine failures was one of the 2021 5.3l that had a lifter problem.
None of the other Tahoes with 6.2l had any issues.
As you mentioned checking the records you definitely want frequent oil changes less than 5k, and using 5-30W or 0-40W.
Also important-look for trucks that don’t consume oil between changes (if you can get that info) as some on this forum have mentioned that they are having to add a quart or more! There are plenty of trucks like mine, and others on the forum that use no oil between changes.
I can’t say for sure but this might be better than any Pico test for checking quality control.
I change my oil way before it gets over 4500-5k miles which is frequent but it never needs any oil added. It seems very strange that some use a quart or more and others don’t use any. It is the same motor so that has to be important data.
For the model years you are looking at Carbyte and other companies make several solutions for eliminating auto stop and the cylinder deactivation.
I like the plug in Carbyte as it is easy to plug in and just unplug for trips to the dealer or over air updates, but I think most of these solutions are something you want to see on the truck.
For the magnetic ride, I am pretty sure all in that year range have it.
I would highly recommend the air ride option if you are going Z71/off road or towing.
I noticed big improvement in ride and performance and I think GM has the air suspension dialed in
For testing the air suspension - cycle through the modes by using the dial on panel.
Remember that if your stopped and door is open it won’t go through the modes.
On the system menu you can select entry/exit height and just a short distance in drive you should see the icon indicating it is changing. When stopped and put in park it should lower in a couple seconds if you keep door closed.
It should function smooth and while it does take some time it should be smooth and complete.
Mine still works like new even after trailering a lot and putting 600lbs of tongue weight on the hitch multiple times and pulling the boat/trailer out of the water using steep ramps.
I have been really surprised by how all the technology stuff has held up over time like ventilated seats, cameras, all the powered stuff like that panoramic sunroof and the seat adjustments.
I have been caught more than once in Florida downpours that have soaked me and the door in those seconds of opening and closing.
I try to dry everything off but everything seems to get soaked in those situations.
Doesn’t seem to affect any of those door controls at least yet lol :)!
Coming from the Wrangler your wife is gonna love it!
By the way I looked at some of those options you mentioned - Land Cruiser and GX550 and the Tahoe is a much better truck and way more driver and cargo space than any of those.
JKeller
This is all anecdotal rather than evidence, but my experience with my 2015 5.3, 2021 6.2, and 2026 6.2 is that they all consumed oil when 0w-20 was used. That consumption went down significantly when I moved up to 30w oil. The consumption then went away completely when I installed the Range device to disable AFM.
BacDoc
Vero Beach Florida
All our experiences here are anecdotal but I find the oil consumption extremely interesting.
Same engine and some report a quart or more between changes and some report 0.
Driving conditions and viscosity are variables but I was using 0-20W before the recall and after my Tahoe went in for the inspection it’s been 0-40W.
As long as the truck is under warranty I will take it to the dealer for oil changes.
I still think that the same engine, new through 30k+ should have very similar oil consumption between changes.
We are not talking engines with over 100k miles but new engines.
How can there be that much difference?
As I have posted before, my driving falls under “severe” driving, towing a lot and daily short trips.
My last couple vehicles bought new, have never used oil between changes.
My last vehicles that used oil were a 1990 Ford Explorer and the VW buses I had as my first cars.
I used to carry extra quarts in those all the time!
thetremorbuild
Penngrove, CA
@t_bergman, for a current-gen Z71 wheel/tire reference, my 2026 Suburban Z71 runs Method MR318s with Mickey Thompson Baja Boss 275/70R18s. I can’t speak to 2023–24 fitment or wear from ownership, but figured this setup might be useful while you’re comparing tire options.
alexblagoev
