2022 Tahoe Winter Wheel Options - Do old Tahoe wheels fit?
Mar48
I’ve been looking online in anticipation of receiving our new ‘22 Tahoe, and it seems most wheels for the new Tahoe are advertised as 2021-22, whereas prior model Tahoe wheels end at 2020.
I tried looking at bolt pattern, width, offset, etc and don’t see a reason why they wouldn’t fit. Can anyone confirm that prior model Tahoe wheels fit? There wasn’t a hub/center bore change, was there?!
Thanks in advance and apologies if this was covered already.
Big Mama
Virginia
Correct, they’ll bolt right up. Remember to have tpms on the winter set.
M
Mar48
Thanks!!!
Also, not worried about offsets (very familiar with how offset/width work - but appreciate the call out)! Even the same model can have different options with slightly different widths/offsets... I'm seeing most earlier and current model 20-22" wheels have 9" width with ET 24-28 (so fairly similar)
cdgtahoe
Austin Texas
Thanks!!!
Old Tahoe wheels will rub on brake caliper since it is a different design. Since GM went to fixed design where pistons on both sides. The side by the wheel has extra boss sticking out. Old design was a sliding caliper. New one is not.
olyelr
Elk Rapids, MI
Yes i just read a post where someone was needing wheel spacers with their oem reps due to rubbing somewhere on the brakes or something.
olyelr
Elk Rapids, MI
Here is the link….
willie110hh
