2020 Yukon SLT - Tire Pressure Monitor Sensors
2Luckysat
Hey Fellas,
Have a 2020 Yukon SLT 5.3 4x4 83,000 miles with Max trailer package.
Started truck the other day and got double dashes for two front tire pressure readings (see attached photos). Does this mean sensors are shot? If so should I change all four? Seems a little early... Also does anyone have suggestions on a good place to order sensors. I saw two part numbers available. Thanks for sharing your hard earned knowledge and experience any help would be greatly appreciated.
RST Dana
EMT/First Responder Firefighter Supporting Member
OH
Discount tire have a better warranty and cheaper than gm
GMCChevy
I have one that age that's no good. My tahoe has the fancier dash but when started it gives some warning about the system and the warning light stays on and the screen that shows the readings has one out. It was tempermental before it stopped all together.
I haven't replaced it yet but have seen people complain about some aftermarket ones having issues but will be interesting in hearing good and bad opinions about them LOL
I plan on only replacing the bad one since some of them can last a long time.
I would first try the TPMS sensor relearn procedure, just in case there was a onetime system communication failure. If the relearn procedure is not successful, then proceed with the following.
Do you have, or have access to, a quality bi-directional scanner? You can use the scanner to isolate the source of your issue. It could well be that one of your TPMS sensors has failed, but the scanner will confirm, or point you in another direction for the root cause.
I would only change out the failed sensor, and replace any others that fail in the future at their time of failure. After all, this is not a critical failure that is going to strand you anywhere.
If a TPMS sensor replacement is required, I would go with a GM/AcDelco brand, but that is just me. If you decide to go with another brand, make sure that it is compatible with your truck's model year.
Hey Fellas,
it might be worth trouble to have the battery tested, if that passes then try a relearn and see if it re-occurs, if so then proceed accordingly
2Luckysat
Thanks for the input fellas. I bought an inexpensive TPMS relearn tool on amazon for $9 bucks... Could not get any action on communicating with front two tires. Wound up taking the truck over to my local tire shop they said front two sensors were shot... I asked them to change all four, they pulled the wheels and installed four new "Autel" sensors and relearned the TPMS computer on my truck for $45 per tire totaling $180 out the door. The whole process took about an hour. Not sure if Autel brand are decent aftermarket sensors but everything appears to be working well at the moment. Honestly six years and 83K seemed early to me.
alexblagoev
