2020 Tahoe RST - Fog Light Upgrade?
MattM45
Hi All - Had a question for the group on upgrading the fog lights on a 2020 Tahoe RST. I’m looking to do as simple an upgrade as possible so that the fog lights match the same intensity as the headlights. Both the headlights and fog lights are completely stock. The fog lights are this weak shade of white/yellow compared to the LED headlights.
Really appreciate the help - Matt
I use HeadlightRevolution.com for all of my lighting needs. They are knowledgeable, have products to fit most budgets, and their customer service is excellent.
tuckerrnr1
Port St Lucie, Florida
I use a LED bulb in the replacement size from Amazon. They lasted over 7 years in my 2010 and have been going strong for 3 years in my 2016. They a a significant improvement over the stock incandescent bulb.
LSCALADE
There are LED projector elements built into units you can swap (entire housing); they go for around 70$ and then there are light bulbs you can put that will give you a lot of light scatter but a good match to the headlights for about half the price. One is simple plug-and-play; the other will require removing the old housings out and installing new ones. Some come with a DRL, which will need further wiring.
M
MattM45
Thanks so much - I’ve got the stock HID/Xenon headlights. Do you have a recommendation by any chance on a bulb swap that would get the fog lights to match up with the headlights as closely as possible? Really appreciate your help - Matt
diode dynamics ss3 max, in a true fog pattern, top is no fogs, bottom is with fogs, gives an easy 20+ feet of view on each side of the road.
and the pattern does not blind anyone as long as you aim them correctly.
these put pretty much any fog light to shame.
BigBoyZ71
Calgary, AB
^I have the SS3 kit as well, highly recommend. However, it depends on what aesthetic you're going for. If you're okay with fluted lenses, SS3. If you want a smooth lense, something like the morimoto XB fogs.
A drop-in bulb won't give you much in terms of performance other than matching the HID color.
LSCALADE
Info on those brakes? I like the set up.
M
MattM45
Thanks - Wildwood big brake kits on all four corners. TX6R kits on the front with 16” slotted and drilled rotors and 6 piston calipers. TX4R kits on the rear, 16” slotted and drilled rotors and 4 piston calipers.
Chevy1234
