2019 Suburban — front vents blow hotter than ambient, rear is fine**
man0war
Front A/C has been intermittent all summer. Hot 100°F day it blew straight hot. Cool cloudy day it was acceptable.
Cold at highway speed, warm at idle, better if I hold 1500 rpm. But then again there would be days it simply won't push cold air.
Refrigeration side checks out at 90°F ambient. Static 120/125 equalized, idle 50/240, at 1500 rpm 35/275. Fan pulling hard, compressor steady, no cycling.
The tell: **front vent reads 104°F at full cold with the A/C button off and blower max. Ambient is 90.** Full heat gives 150. So the door reaches its hot stop but won't close off the heater core at the cold end. Rear vents are fine — 75 vs 87 front at the same moment.
Already pulled power to force an actuator relearn. No change.
Looks like the front blend door actuator, but I've seen threads where people replaced it, recalibrated, and still had hot air — turned out to be the headliner interior temp sensor.
Questions:
1. Anyone seen the headliner temp sensor cause this on a K2XX?
2. Are the driver and passenger temp actuators the same part number on 2019? Listings seem to stop at 2018.
3. Can anyone confirm actuator locations for 2019?
4. Any other thoughts of what's happening here.
Cheers!
alexblagoev
