Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Considering future trans service (when that time comes), is it going to be a big deal getting than pan down any input would be appreciated. Is the gasket reusable (my wife’s envoy had a steel gasket on it) ?
The best bet is to pull the exhaust. I would be hesitant to "pull" it down like many do. Adding unnecessary stress has the potential to create cracks down the road. I do believe the pans have a reusable gasket as well.
The 2019 and 2020 do have a dipstick. Opening up the pan to clean it out, replace the filter, and especially clean off the magnet is a really good thing. Perhaps replacing the pan with one that has a drain plug would also make future services a breeze.
i followed the severe maintenance schedule & chg'd it @ 45k
just had the dealer do the fluid exchg, as they recommended.
i even inquired about chg'ing the filter & they said not needed this early
they said @ 90k to drop pan & chg filter
i'll probably chg it closer to 70-75
It depends on what you do. Having a minty clean pan and fresh filter always seems like a good idea to go along with fresh fluid. But it's definitely more work involved. It's up to the end user.
Error to the side of caution. If I am doing a trans flush the filter/screen is going to get changed and I want to see inside that pan and also clean the magnet.
Does anyone have experience removing the exhaust flange bolts on a regular basis from new? Do they remain removable after 2-3 years and 45,000 miles, or do you have to remove them sooner to keep them servicable?
It depends on how rusty and crusty they are. I haven't looked yet to see if they are bolts and nuts. If they are bolts and nuts, worst case you cut them off and then install new bolts and nuts which is relatively easy to do. Penetrating oil for weeks in advance also helps.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
