2018 Suburban 3500 HD first mods and discoveries
Langosta39
Good morning All!
We've had our 2018 Suburban 3500 in the driveway for a week now and I've been planning out the mods to get it where we want it. First trip towing our 25ft 6000lb camper is Oct 5, and first trip towing the our enclosed cargo trailer (to pick up a 1954 Land Rover Series 1!!!) is this weekend so no time to waste!
Husky X-Act fit liners arrive tomorrow, no doubt that these will be great.
Ordered Morimoto HID low beams and LED high beams in 5000K and 5500K to match the DRLs, they also arrive tomorrow. Pulling the OEM bulbs to check the plug orientation was a pain with the battery and air cleaner in the way, so I'll be pulling those out for the install. If all is good I'll post details of the part numbers I ordered.
Picked up some 2025 Silverado 3500 wheels, 18" machined aluminum, photos coming.
Ordered 275/70R18 Mickey Thompson Baja Boss A/T tires, Load Range E of course. These get installed Saturday morning and I'll take measurements before and after.
Whether or not the new tires rub I'll be ordering Kryptonite torsion bar keys to raise the front end up a bit, and if I have to go more than 1" I will also get Kryptonite or Cognito upper control arms to improve the geometry and ride. For both of these items I think I need to order parts for a 2010 or older Silverado 2500/3500HD and not the newer style chassis, but the jury is still out.
I want some rake front to rear so I don't squat while towing so if I need to I will add 1" blocks since the factory rear leaves are right on the axle perches.
The factory 17" wheels (with stock 265/70/R17 tires) are in good shape so I may put studded tires on them, but the Baja Boss A/Ts on my pickup are pretty amazing in the snow.
More to come,
Andy
Geotrash
Dave
Richmond, VA
Good morning All!
More to come,
Andy
You're on your way! Keep the updates coming and don't forget the pics! On the control arms, check out whatever Duramax Specialties is using for their diesel HD Suburban builds. I'm of the understanding that whatever fits the pre- 2013-vintage 3/4-ton Suburbans will fit these.
L
Langosta39
Good evening all,
The Husky mats are a win... much softer, more pliable, and quieter than the Weathertech option.
Morimoto HIDs for the low beams and LEDs for the high beams worked out. The HID kit was a pain. The cables are juuuust long enough for a fullsize truck, the connectors are too large to fit through the hole you have to drill in the dust caps (use 7/8 not 3/4 as instructed) so you have to de-pin the connectors. Both H11 bulbs had one of their tabs break off during install. All in all, not impressed with the kit, but we will see how they perform. So far they at least appear to match in color to the DRLs and high beam LEDs. The LEDs were super easy to install except that our trucks are so tight in the headlight area.
LEDs: 9005/H10: Morimoto 2Stroke 4.0 LED Bulbs
HID Kit:
H11B/H9/H8: XB 5000K HID Bulbs
HD Relay: H11/H9/H8/880
35w / AMP: Morimoto XB Ballast
PWM Modules: Morimoto Anti-Flicker Cap. Link (not convinced this is needed)
Tires on Saturday! Stock height from ground to wheel arch (centered with the hubs) my truck was 36.5" front and 38.5" rear (driver and passenger were the same). Have not gotten leveling kit parts yet, but I cranked the torsion bolts 4 full turns to get ready for the larger tires. That netted right about 1" more height on the front and looks less saggy. If the new tires clear I'll just put on Kryptonite keys and see how it goes. Kryptonite looked at the images of my suspension and confirmed that their pre-2011 Silverado 3500HD parts are the ones to use.
L
Langosta39
Here are the new tires and wheels, I'm really happy with them! 18" wheels from a 2025 Silverado 3500 and 275/70/R18 Mickey Thompson Baja Boss A/T combo. Very slight rub on the rear of the front wheel well liners at partial turn, so I'll lift the front another 0.5 to 1.0 inch and see how it goes. The Kryptonite Stage 2 kit (KR10STAGE2) is sitting on the shop floor and might be this weekend's project.
With the new tires the fender heights are 38.5" front and 39.5" rear with the tires at 60/65 psi. By the numbers the new tires should have added 3/4" over the stock tires but I got a full inch more radius.
After a few days of driving in the dark I've decided I'm not thrilled with the color of the Morimoto HIDs. I've asked if I can exchange them for the next step up in color temp.
Had every seat full and 6000lbs on the hitch coming back from Idaho on Sunday. Went over Thompson Pass on Hwy 471 which peaks at 10+% grade along a 2000ft climb and the truck did great. I wasn't holding the speed limit, but the L96 was perfectly happy to spin at 4k RPM and the tranny temp just touched 200 and dropped quickly grade braking down the east side. My previous family tow vehicle was a 2022 Ford Expedition with the 400hp Ecoboost and 10 speed tranny and 3.73s...it had the power to go but lacked the engine braking for steep descents and the chassis stability in windy conditions and rough roads...it also was at max rear axle rating when loaded similarly. The 3500 Sub was solid as a rock, absolutely no regrets.
L
Langosta39
Morning all!
I got under the truck this weekend to prep for suspension install and I discovered something that saved me a lot of money. With the torsion bars where they are I've got just over 2" of down travel from ride height which is plenty tolerable for ride quality. The rubbing was on the rear of the wheel well liner on the driver side and passenger side. The passenger side was way worse and a screw head was making a noticable wear pattern on the edge of the tread face. I took the screw out and looked behind the liner; all of the rubbing was due to a sheet metal tab for mounting the liner that was leaning a bit forward. So, I took a vise grip pilers and tweaked it back about 1/4" and then use a dead blow to shape the sheet metal ridge that goes from the cab corner to the liner mounting tab. I then took a heat gun to the liner to make it a bit pliable and molded it to the new sheet metal position. Overall I gained at least 3/8" of horizontal clearance with no cutting or damage to paint or metal. I did some crawling through ditches along our road and am satisfied that 100% of the rubbing there is gone. There is a tiny bit of rub on the driver side sway bar at full lock but its just the sidewall lugs and it is almost unnoticeable when it happens. So, the lift kit goes back, the truck looks great with factory parts adjusted correctly, and all I need is an alignment to make sure the new tires will wear well.
Geotrash
Dave
Richmond, VA
Morning all!
Wonderful! That'll save you some money and hassle. Nice work.
Geotrash
Dave
Richmond, VA
Wheels and tires look great!
Bigburb3500
Morning all!
Love this. Once my BGFs are done then I will likely do similar sized tires. Did you use spacers or did the 2025 wheels bolt right up?
L
Langosta39
The new wheels bolted right up!
The speedo was 1mph under at 70 and now it is 2mph over (according to Google Maps GPS), but I've heard that Chevy dealers are sometimes willing to adjust tire size.
I would also really like to get my TPMS warming threshold adjusted. With a 6200lb rear GAWR and tires that are rated for 3640lb @ 80psi they only need 68psi to handle max weight and only 55psi to handle my whole family with 1000lbs of tongue weight, but the TMPS warning goes off somewhere around 60-62psi for the rear tires.
On that train of though, my current camper is 6500lb GVW and last week I took it over the scales to see where I stand.
Truck with Family and Full TankPlus Camper (without WD hitch)
Steer38403480
Drive37004980
Trailer05340
Total754013800
The camper was loaded with fresh water, empty grey/black, and no generator this time. It's pretty clear that the camper is right at its GVWR and due to the spare tire, propane tanks, and storage tunnel all being at the front the tongue weight is around 15% or 1000lbs give or take. This also means that my factory hitch it at its max tongue weight rating so I would really like to find one of the those Curt class 5 hitches for margin. I plan to get a bunkhouse camper to hold my 5 growing kids and those come in around 8000lbs GVWR on the low side so tongue weight will be well north of 1000lbs if the pattern holds. My WD hitch from the Expedition didn't have enough holes left to drop it enough for the Burb so I ran with my 15klb aluminum drop hitch. A WD hitch would probably put a couple 100lbs back on the front axle and maybe some to the trailer axles, but I'll have to test that at another time. In any case I still want more margin on the receiver rating.
All in all I was pleased with the truck towing 650 miles from Kalispell, MT to Bozeman, MT and back. The back roads to I90 were a non issue between 60 and 70mph. There are some good grades on I90 that had me in 3rd gear a few times, and on the way home there was a not-so-uncommon 20mph headwind with 40mph gusts that kept me in 4th gear at 2500rpm and 60mph for about 100 miles. The truck was delightfully solid especially without a WD hitch, but with that kind of wind there's no reason to push the speed and if I did I probably would have been in 3rd gear getting 4mpg. The overall mileage for the trip was 7.9-8.0mpg (hand calculated) which is just a hair less than our Expedition got on a similar run.
I'm considering a cold air intake and tune to get a wee bit less downshifting while cruising, but we'll see.
Geotrash
Dave
Richmond, VA
Steer38403480
Drive37004980
Trailer05340
Total754013800
Note that the upgraded Curt hitch will interfere with the spare tire hoist socket. I had one I was ready to put in and decided not to, even though my 7,700 lb Airstream also has a 1,000 lb tongue weight (actual measure).
People have been quite surprised by what the factory hitch will actually handle - I've seen people run the factory hitch (same hitch) on their GMT900 3/4-ton Suburbans with a 1,500 lb tongue weight and a 10,000 lb cargo trailer full of snowmobiles and gear. But they've been equally surprised to learn that while the hitch itself held fine, they bent the aft frame rails it's mounted to.
Not sure if I mentioned it, but Duramax Specialties has a reinforcement kit for the frame. I have the kit but haven't installed it yet. Either way, I've been considering finding a good fabrication shop to look at the factory hitch and see what they can do to make it strong enough to handle 25-30% more tongue weight for extra margin, once I have the frame reinforcements installed.
L
Langosta39
Sounds like the reinforcement kit is something that I should have unless I upgrade the receiver hitch to one that extends past the weak section of frame.
I've found references to it but not sure I actually found links to buy the right thing. Is it a weld in solution or bolt in? Their FB page mentions a bolt in solution "coming soon" a year ago.
Do you have a link or part number for what you bought?
Bigburb3500
I towed my dad’s ~6500 lb boat and no issues either. We had the full crew in the truck and the only issue I had was some wallowing on the really bad roads we were on in OH. Otherwise 6-8klbs sounds like this truck’s “sweet” spot with all of us haha!
@Langosta39 - Definitely get a tune. Both Geo and I have a BlackBear tune and it’s 100% worth it.
Geotrash
Dave
Richmond, VA
It's bolt-in. And getting one on the way took some time because I think Nick is careful about who he'll ship an experimental kit to. I've spent a fair amount of time over the past couple of years trying to be helpful to folks on the Duramax Specialties FB group, and I've expressed support for the work that Nick is doing at DS to make outstanding Duramax powered HD Suburbans, Yukons and Escalades. He really does make the best, in my opinion. He also knows that I own a Suburban 3500 HD, which he's commented on a couple of times. Anyway, I'm not truly sure how much all of that mattered but it seems important background.
Then, on each of the posts Nick made mentioning his progress on the reinforcement product, I said something along the lines of I'd be ready for one whenever he feels comfortable to ship it. And eventually he responded to one of my posts asking me to DM him directly. So I did, and I caught him on vacation, lol. But he asked me to write again in 10 days, which I did. I also made it clear in my message that I didn't mind if the kit wasn't perfect. I know a good 4x4 guy and fabricator I'd work with to get it adjusted, if needed, and installed right.
He gave me a number and I sent a Venmo a few minutes later with my address. A few days later a box showed up on my doorstep. The kit is finished beautifully, with good quality hardware to go with it. I'll post a pic when I have a moment.
Bigburb3500
You didn’t tell me you got your hand on the kit! Definitely need pictures as I’m heavily interested as well… I need to make a FB account just so I can follow stuff like this.
thetremorbuild
Penngrove, CA
Those Baja Boss look great, nice find on the sheet metal tab causing the rub. I'm running Baja Boss in 275/70R18 on my Suburban too (on Method MR318s). Did you ever get the TPMS threshold sorted out?
L
Langosta39
Ah love the Methods! I was debating between a nice set of matte black 18s and the factory Silverado wheels.
I have not gotten to the dealer to address the TPMS threshold, but now that its getting below freezing at night and I'm getting warnings every morning I'm more motivated to do it.
thetremorbuild
Penngrove, CA
Thanks, Langosta39. Both are solid choices, so I don't think you can go wrong either way. Hope you get that TPMS threshold sorted before the mornings get any colder.
Bigburb3500
You motivated me to get the tow mirrors. Found a used set on marketplace and then paint matched them. I don’t have all the lights hooked up yet but that’s for another day. These are SO much better than stock. The original are garbage.
Running KO3s on mine. These trucks are heavy and we do regular beach drives. They are great once aired down.
L
Langosta39
Oh good find! I read there is a version that has power folding in addition to all the lights. I would love to find some of those, but then probably would need new controls for the door that have the fold button.
Love the KO3 look, you even went old school with the white letters out! Works well with the white truck.
Bigburb3500
Thanks! I don’t think power fold is available on any of the tow mirrors for this gen… I think the sport mirrors and Cadillac mirrors are power fold but haven’t seen the tows.
First time I’ve done the whites out and I’ve run BFGs for the better part of a decade on different trucks. Thank you! 20k miles on them so far and doing well. They are just a heavy freaking tire. Next up will be doing the increased size like you. I’m a sucker for the OEM+ look.
Do you know who made the marker lights for your truck? I’m kinda envious.
alexblagoev
