2017 PPV/Hi I'm new here
gpzTurbo
I bought a '17 ppv with a bad engine, replaced it with a Callaway 5.3 pulled from a wrecked Silverado, did the afm delete and cam then beat the snot out of it for ~30k miles until it spun a crank bearing.
I just asked for an update on the thread where Max was doing a L8P crate engine in his ppv. I'm leaning that way.
TML_75
Welcome. Look into the search window to see if there’s a post already about your crank bearing
poleec_hoe
Curious to see how the L8P swap goes. I haven't done the AFM delete on mine, plan is when/if it ever explodes I'm going 6.6 swap.
I saw that one guy do it on a Suburban and seemed pretty bolt on. I figured it might be harder on the Tahoe since the wheelbase is shorter. (Going off memory here) the 6L90 is longer? so he needed a slightly shorter
thatboy_eddie
