Blackcar
- Joined
- Mar 31, 2018
- Posts
- 640
- Reaction score
- 528
Today after filling fuel tank started up truck drove a little ways and Service Trailer Brake System? Haven't use system and truck only has 14000 mile 2017 Denali.
Went to dealer battery voltage low they replaced battery haven't seen message since. Two year old battery !Still under warranty? Check the connector next to the hitch, you can unplug it from underneath and clean out all the dirt/dust. If you have an advanced scan tool, you can pull up the code that triggered the message. Somewhere underneath is the solid state relay (SSR) and trailer brake control module (TBCM) which interact with the BCM, ECM and EBCM (brakes). Check the connectors on those if you can find them. On my generation, they were not where the manuals said they would be. The SSR turned out to be in front of the fuel tank and the TBCM mounted on the driver's side frame rail.
