I cannot assist you, as I am not that familiar with you model year/generation. Other folks on this Forum much more knowledgeable than me on your truck will chime in.
In the meantime, I asked Grok, using your own words, and this is the reply.
Fuse 29 (Radio) in the right-side instrument panel fuse block is confirmed for the 2015–2020 GMC Yukon/Yukon XL (and related K2XX platforms like Tahoe/Suburban). It powers the radio/infotainment circuit, which includes the head unit (radio/ACM), HMI module, and related items such as the center console USB hub (and RSE elements on equipped vehicles).
Your progressive failures (lasting a month → weeks → a day → instantaneous) are classic for a developing short to ground that has now become solid. Disconnecting the USB hub did not stop the blow, so the short is upstream of or parallel to that branch—most likely in the wiring to the HMI, head unit, or shared harness runs.
Wire color
Factory diagrams and aftermarket radio wiring references for the K2XX platform (2015–2020 Tahoe/Suburban/Yukon family) list the
battery/constant 12V+ power feed as Red/Violet (red with violet/purple stripe). This matches what you found via Google. Ground is typically black. Confirm with a multimeter on the load side of the fuse socket (key off, fuse removed) rather than relying solely on color, as harnesses can have minor variations.
Components on the circuit and isolation steps
The fuse feeds the radio/head unit, HMI (Human Machine Interface module—the “brain” for the screen/touch interface, usually behind the glove box area), and the center console USB hub (plus RSE where equipped). Your plan is correct:
- Disconnect the USB hub (already done—still blows).
- Disconnect the HMI connectors (accessible after removing the glove box/trim; look for the multi-pin plugs, often with a security tab).
- Disconnect the head unit/radio connectors (requires dash trim and center stack disassembly).
Install a known-good fuse of the correct rating only after each disconnection and test. If the fuse holds with a given component unplugged, that unit or its immediate pigtail is the culprit. If it still blows with all three disconnected, the short is in the vehicle-side harness between the fuse block and the components.
Safety note: Disconnect the negative battery terminal before unplugging modules. Use a multimeter to check for continuity/short to ground on the load side of the empty fuse socket (near 0 Ω to chassis ground = short present). Avoid repeatedly installing new fuses while the short exists.
Common routing and pinch/chafe points
Wiring leaves the right instrument panel fuse block, runs through the passenger-side dash area, and branches toward the center stack (head unit), glove-box area (HMI), and center console (USB). Typical problem spots on these vehicles include:
- Passenger-side kick panel / lower dash junction and harness pass-throughs (sharp edges, body structure, or clipped routing).
- Behind the radio / HVAC ducting and center stack (harness can get pinched against metal brackets, the radio housing, or during prior work).
- Around the HMI mounting area behind the glove box (connectors and nearby harness).
- Any prior dash/console work (your HMI upgrade is a possible contributor if a wire was pinched or insulation damaged during reassembly).
Chafing against sharp metal, brackets, or HVAC components is a frequent cause of progressive shorts that eventually become hard faults. Inspect for melted insulation, exposed copper, or wires pressed against metal. Gently flex/wiggle harness sections while monitoring continuity to ground to catch intermittent spots.
Wiring diagrams
Full factory schematic packages (radio circuit group) are available from sources such as AutoRepairDiagram and similar service-info sellers; they show the exact fuse-to-component runs, splices, and connectors. Owner’s manuals only give the fuse assignment (Radio = #29 right IP block). Aftermarket radio install sheets for the K2XX platform also confirm the Red/Violet constant power and black ground.
If isolation points to the HMI or head unit, those modules can fail internally and draw excessive current. Because you already replaced the HMI and the problem returned (and now blows instantly), wiring damage or a secondary short is more likely than a pure module failure—though a new short inside a module is still possible.
Work methodically with a multimeter, inspect the known pinch points carefully, and repair any damaged sections with proper solder/heat-shrink (not just tape). If the short remains elusive after disconnecting the three main loads, a dealer or shop with full GM service information (or a paid diagram set) can trace the exact circuit. Let me know what you find on the next disconnection steps.
