2015 Yukon Denali power liftgate will not CLOSE automatically.
Tarryl Madison
Opens with no problem using the fob, handle button or overhead button. Will not close with any of the above or the close button on the bottom of the gate itself, so I always have to shut it manually. If I hold the close button long enough I get beeps along with a flash of the turn signals, but nothing happens. Any ideas welcomed...
Big Mama
Virginia
No mechanical sound when you try? No motor sound or clicking? When you do it manually does it close smoothly? Check connections to the actuators. Here’s an old post that may help.
Tarryl Madison
Tarryl Madison
Everything opens fine, no unusual sounds or anything. I've seen where some people suggested checking fuses but they all check out. Here's a pic of my interior fuse cluster. Am I missing anything?
Big Mama
Virginia
I think in the old post he ended up getting new actuators. At 10 years old they’re probably tired. You can always get the from Amazon and return them if they don’t fix the problem.
Big Mama
Virginia
it sure sounds like something obstructing it but Joe cleared that. How a loud chaffed wires from top of rear into the llift gate? I know I’m grabbing at straws now.
PG01
Up here to the right
Well, technically you can instruct it how to close with your hand but sometimes inanimate objects don't listen very well….
zoongizi
