2015 Tahoe radio display fuzzy
TimHealy
I have a 2015 tahoe, having radio issues. Display is all fuzzy in the normal mode but in reverse the screen is fine. Any ideas?
could MAYBE be a bad connection and the reverse signal could maybe be on a different connector, but GM being GM they will probably suggest replacing the screen instead of trying to fix it since it is a whole unit. unless you happen to have a GDS2 tool to test the display then you will probably have to take it to the dealer, this is the test they do
MyCleftNut
