K9ErnieSSV
- Joined
- Jul 18, 2021
- Posts
- 10
- Reaction score
- 13
Having issues with the HVAC. The drivers side was not cool and the left side window defrost was full hot. Read that you can clean the temperature actuator to fix. Now the front and back don't go full cold and are both tied to the left temp control. Right wheel does nothing.
Is there a scan tool that will be able to read the actuator and perform a relearn? I see that things have changed with AcDelco and using the MDI2. Is there a different option that cost 500 or less that would be able to work with the HVAC module? Hopefully other modules as well.
Seems easy going down the rabbit hole with scan tools and what modules they can and cannot work bidirectionally.
I would prefer not to have to get a subsciption or shell out a grand for a scan tool and I have a feeling going with the clone will stop working soon since they are forcing users to connect online to use the MDI2's (unless I am mistaken).
So much to learn and little time as I have a retired K9 unit and need the AC working since it still gets warm in southern Florida. Appreciate recomendations and assistance.
