Just00Jake
- Joined
- Jun 27, 2022
- Posts
- 63
- Reaction score
- 41
I've got lifter/rocker noise on passengers side. I've recently done a top end clean, to remove carbon that was causing my exhaust valve on cylinder#2 to stick at low rpm. It worked, I no longer have a misfire. About 3 days later I started getting a light tapping sound. I thought I needed to change the oil but it had not been over due. It run full synthetic. The next day or got louder and before I changed the oil I thought I'd remove the valve cover to do a visual inspection. Although all of the rocker arms bolts are completely tight I've found that I have play in my #2 front valve (intake I think) and #4 front valve. I recently pulled the valve springs (intake and exhaust) on #2 only to inspect them but didn't touch #4 so it's not from the inspection. I can move the push rods up and down a bit on those 2 rockers. From reading I've come to the conclusion that I should do an engine flush to remove any carbon deposits that may have come loose and might be clogging the oil for through the lifters/push rods and then do an oil change of course. Does anyone have any advice? Is there any other adjustment? I know there is supposed to be a little play but this seems a little too much. I was wondering about the "plungers" if they go bad or an I over thinking this? I appreciate any help
