Marky Dissod
In a WHAT? In a midsize musclecar with under half the aero drag of a pickup truck or an suv that also weighs 2x as much,T56's 6th gear is 0.50, with 3.42 and 6th, was very usable to me.
YOU've nothing to do with how usable 6th gear would be.
Also don't forget that even with that 10L80-specific ATF, the T56 is still inherently more efficient.
Although everything you said is true, you are also missing info. Not referring to spark knock, referring to insufficient low-RpM oil barrier.lugging an engine isn't great for it. but it's because of low rpm spark knock, what's happening with these new 6.2L di engines has very little to do with being lugged around.
they are just plain junk. you can't blame anyone but gm for that trash.
Although 6.2L L87s are strong enough under 1750RpM to not need a downshift, the load was enough to squeeze out the motor oil barrier between crank & bearings
which exacerbated GM allowing badly built/unclean cranks to make it to market.
I can ALSO blame GM for tuning the tcm to not downshift in situations that would jepoardize even a well-built & cleaned crank - you all should.
(GM re-engineered motor oil distribution specifically to address the L87's insufficiently protected crank & crank bearings in the new Gen6 V8s.)
There is a reason why tuners tune the transmission to upshift later and be more eager to downshift with less throttle input:
most people who get their vehicle tuned are willing to lose 2-3MpG to extend the life of the engine and transmission.
