I did not previously look up the brake code it says switch in the scan, but that 1st one points to right front hub/abs sensor.The brake pressure switch has been replaced with a genuine part which made no difference. The evap system has been gone through about 60k ago I’m not super concerned with evap at the moment. The engine was replaced 47k ago with the jasper afm dod delete engine and pcm had jasper tune applied to it. I do not have any misfires or code for them. 250k on body 47k on engine 84k on the transmission.
having it be just the sensor is rare but can happen.
you can swap the front abs sensors and see if the problem follows the sensor, if not then it's likely the hub.
