2011 ppv Tahoe service brakes soon
11ppv
Hello all I am new to the forum and appreciate any advice on this issue. I have a 2011 ppv Tahoe 250k miles that is giving me a service brakes soon message on start up . Then after the above message I sporadically get service stabili-trac service traction control. Abs light comes on and traction control. I have scanned the codes and have C0040 brake pedal switch a. C0299-5A History. I have other codes but do not know if they would affect the issue with the service traction control ,abs and service brakes soon.My other codes are related to evap system and cylinder deactivation. The engine was replaced 47k miles ago with a jasper afm dod delete engine and the computer had a jasper supplied tune installed. The issues started around 2-5k miles ago but was very sporadic and would only come up ever 4-5 hundred miles and would go off on its own. Now the issue starts as soon as the vehicle is started. The service brakes soon message started about 3 weeks ago but the service stability trac abs light and service traction control have been coming up intermittently the whole 2-5 k miles.I have replaced both the brake light switch and the power brake booster pressure sensor with genuine gm parts which seemed to have to effect on the issue at hand. I cleared the codes and drove appropriately 65 miles after clearing and the warning lights continued almost immediately after start up with new parts. I have attached photos of the gauge cluster showing the lights and information it gives along with code scanner results.
Hoeston
Could definitely check the abs sensors' connection but given the codes I doubt it would be that simple
11ppv
11ppv
Are you referring to the sensors on the front hubs? I should probably add Front hubs including sensors were replaced 70k ago.
11ppv
11ppv
I checked the connection in both front abs sensors it was seated well I did not see any wire chafing either. Both from hubs were replaced along with sensors 70 k ago.
Chughart
ive not seen this issue before but given the code and description of the code, id check the brake switch on the bottom of the brake pedal. should also check the brake lights to see if theyre stuck on even though the pedal isnt pushed. what ive gathered with gm, id say its the brake pedal switch itself.
11ppv
11ppv
I have replaced the brake pedal switch with a genuine gm part and the brake lights are only coming on when the pedal is pushed.
Welcome to the Forum from NH.
Pics of the truck, please. If we can't see it, it does not exist.
Your C0040 trouble code and Service Stabilitrak and Service Traction Control directly relate to an issue associated with the front right wheel speed sensor circuit. It could be the sensor itself, debris on the reluctor teeth, the wiring for the circuit, or a control module failure.
I recognize that you state that you replaced the wheel speed sensor 70k miles ago, but that does not mean that it is still working correctly. You state that "I did not see any wire chafing either", but did you perform the wiggle test on the wiring from the sensor connection right up to the point where the wire goes into a major wire cluster?
From Grok:
Why the warnings appear immediately at start-up:The EBCM disables ABS, StabiliTrak, and traction control for the entire ignition cycle when it sees a wheel-speed sensor fault. This commonly triggers “Service Stabilitrak,” “Service Traction Control,” and related brake-system messages (including “Service Brakes Soon” on some scans). Cruise control is often disabled as well. The vehicle remains drivable but with longer stopping distances on slippery surfaces and no stability/traction assist.
The fact that the brake light switch has already been replaced rules out one common pedal-switch-related trigger for similar messages, but it does not address the wheel-speed circuit.
Diagnosis path:
  1. Use a scan tool that can read ABS/EBCM codes and live wheel-speed data (basic OBD-II readers often miss C-codes).
  2. If your scanner is capable of viewing live data, confirm which sensor is bad by watching live data (right-front should match the others at speed; a zero, flat-line, or wild fluctuation points to that corner).
  3. Visually and electrically inspect the harness from the hub back toward the frame/EBCM (wiggle test for intermittents).
  4. Check for bearing play (12/6 o’clock rock of the wheel).
  5. If wiring and play are good, replace the right-front hub/bearing assembly. Clear codes and road-test.
11ppv
11ppv
From Grok:
Diagnosis path:
I have not tried to clean the sensor it’s self. But I did wiggle the sensor and connection.
11ppv
11ppv
I have checked the sensor for play but have not physically removed it from the hub. I have also checked the wheel for play and it does not have any. I will check the live data with a scan tool later and update.
Remove the wheel sensor, inspect/clean it, and inspect/clean the reluctor inside.
11ppv
11ppv
I was able to watch the live data on all 4 wheel speed sensors and all are reading the same number. Also the brake pedal position sensor stayed not applied in the live data until i hit the brakes as it should. I will take off the sensors in a few days and clean the ring as well.
Good troubleshooting job with the scanning live data.
If all of your wheel speed sensors are recording speed, and the same speed, then your issue is not related to the wheel speed sensors or their wiring circuits.
Will your scanner allow you to test the ABS module functions?
11ppv
11ppv
I know it will do the abs brake bleed. I looked up my scanner with my vehicle and it says I can test the abs functions. Tomorrow I will try to test the abs module functions. I appreciate everyone ones help so far with this issue.
11ppv
11ppv
Would an occasional front left brake caliper drag also be caused by this issue? I have noticed the front left caliper occasionally will drag if I let the vehicle sit for a few hours the first few rotations of the tire I hear it drag then it releases. I have replaced all brakes and brake fluid due to the old fluid being dirty. But that was around probably 20-30 k ago all pads and rotars still have plenty of life. I have a nice firm brake pedal and the vehicle stops excellent. I will add on I have been braking when the warning lights appeared on the dash ie the abs and stabili-trac. I noticed my foot was almost pushed back by a force for only a split second then the brake pedal felt normal after that. I’m starting to wonder if my issue isn’t with the abs module or the electronic brake control module.
11ppv
11ppv
Its been happening since I bought the vehicle but never really bothered me because it always freed up at the first 2-3 rotations of the wheel. It’s been like that for 85k miles.
JoeBlobs
Senior Member
NJ
Could this be related to the TSB about cleaning the steering angle sensor? TSB #PI0639C You didn't list this code, but the symptoms seem similar in regards to the warnings.
11ppv
11ppv
I will look for the live data on the steering angle sensor and see what it’s reading.
based on those codes you have some maintenance to do.
probably the brake pedal switch
for the evap it's best to shotgun it and replace all 3 parts plus a new gas cap
if the vacuum solenoid up front one drivers side of engine is not working it could "maybe" be your reason for a misfire,,, that's big maybe
but the misfire and stuck solenoid sounds more like time for a dod delete and maybe lifters
the misfires are likely the cause for stabiltrac/traction control error, the service brakes is likely the brake switch
how many miles on it?
11ppv
11ppv
The brake pressure switch has been replaced with a genuine part which made no difference. The evap system has been gone through about 60k ago I’m not super concerned with evap at the moment. The engine was replaced 47k ago with the jasper afm dod delete engine and pcm had jasper tune applied to it. I do not have any misfires or code for them. 250k on body 47k on engine 84k on the transmission.
alexblagoev
