2011 cadillac escalade is possessed
bde269
all over right now cold south dakota
i have a 11 escalade and she is mad at me. Service side blind zone alert system, SERVICE STABILITRAK, SERVICE TRACTION CONTROL are all flashing, about 1.5 months ago we had the fuse box replaced. so far I replaced a few grounds but nothing fixed it yet. I drove it really quick too and she shifts way hard, I was way eazy on the gas. right im working so this was quick dig into it before work the last 2 days. I will mess with her when im off shift on Tuesday . I got to order a tech 2 but haven't yet this might make that happen asap. this sucks hahah been watching youtube for pointers
try cleaning any mud or dirt off the blind zone sensors and body, they are located behind the rear wheels at the rear bumper cover left & right side, they are rectangular shaped like a claymore. stabiltrac may be a wheel hub gone bad, a tech2 would tell you which one or what the error is. sure would be nice if they just put the details of any errors in the dic to make everyone's life easier.
Mike L
We have a 2010 GMC Yukon XL Denali with 6.2L AWD with almost 160K miles - a similar vehicle. We experienced many of the same problems about 25,000 miles ago, and in typical fashion, when I took it to the dealer, it wouldn't act up. I started to notice a pattern of when the systems you mentioned would start flashing, the radio going dark, and the engine & transmission basically becoming unresponsive while driving). I took it back to the dealer and had their chief mechanic go for a ride with me, and sure enough, it acted up with him in the car! It turned out to be a main computer problem which, as I now understand, has been a fairly common problem with these '07-'14 trucks. Now, that said, separately, we have also had fairly hard down shifting from time to time, at least that's what it felt like. It turned out it wasn't a transmission issue, but rather, engine mount issues - another very common problem with these same year range trucks. So my guess is at a minimum, you likely have a main computer problem. You may also have one or more broken engine mounts that need to be replaced. Hope this helps, and good luck!
bde269
bde269
little update I did to grounds one by the drivers side fire wall going to the alt housing still not clean but on, and a 6g lead coming from the neg terminal to the block on the pass side. I used a friends scanner and read all the codes. I read them all im sure some came in because one or more snow ball effected them. I still need to check a few more grounds but I cleared the codes, drove her around slowly and all was good.
the next day we got her cleaned at the car wash and in the middle of the wash the locks unlocked and locked and that's been the only thing weird so far. im back to work so looking at more stuff is out for a few days but as of now shes running good well see and thank you for all the good input
U0073 control module communication bus A off
U0100 lost comm with ECM/PCM A,
P0693 fuel pump control module requested MIL illumina,
P0700 transmission control system (MIL request),
P2544 torque management request input signal A
U0101 lost communication with tcm
U0122-00 lost communication withvehical dynamics control
U0121-00 lost communication with antilock break system abs control module
91RS
GA
Without a proper scan tool, you are completely wasting your time and money. There are over 20 modules in these trucks that a little code reader cannot communicate with.
DefiantOne
