2010 Tahoe dies in traffic in hot weather
kbuskill
NE. FL.
These are all good suggestions, however the P0601 memory checksum error is the same recurring code I was having when sitting idling in hot weather and the truck would just shut off.
New ECM and all is well.
houstontaylor
I once had those symptoms happen to another car due to a bad camshaft position sensor that would come back on when it cooled down.
S
Scottm AZ
Thanks everyone, I am weighing all the options. Marky, thanks for the link to Pcm Perf. I emailed them on ebay and they say their ecm's don't need the relearn, but then I followed the link Fless posted. The procedure lets the ecm relearn the characteristics of the cps and chart the imperfections in the reluctor wheel, which sounds to me like something that should be done properly. Is there anyone on here in Phx with a Tech 2 scanner? What do you guys think of the imitation Tech 2's?
The good news I don't have an LC9 with afm. But it hesitates and lurches and hunts for gears all the time and isn't much fun to drive, so I was hoping turning off AFM would improve that. Flashmaster and PCM Perf can turn off the AFM for another $150 or so, but can't do any other tuning. Black Bear wants $750 for a tune that can turn off stuff you don't want and fix everything else. I have emailed them three times to see if they will sell me an ecm outright with the tuning in it but have gotten no reply. I don't beg anyone to take my money, so they can eat shit.
If I change the cps AND the ecm, will it run well enough to get to a shop? Should I do the cps first and hope it doesn't need a relearn until I can get an ecm? I'm going to call a dyno shop tomorrow that is known for being cool with things like this.
S
Scottm AZ
John, that's pretty corroded alright. Mine's an AZ truck and doesn't have much corrosion anywhere. I took the relays out one at a time and all the pins were clean and tight. I did lever the relay panel out of the box, but the wires were too tight to get a look at the underside. I gave the relay box a hell of a good smack with my fist last time it died, and it has been behaving since.
S
Scottm AZ
Kbuskill, because of the p0601, I am most likely going to replace the ecm. The flashmasters is only $150, but they don't change anything or fix the internal flaw that causes the problem, so how do I know theirs won't still have it? PCM Perf sells a completely new unit for $350, but again they don't fix or change anything in the circuitry.
kbuskill
NE. FL.
I'm not aware of any real "fix" for it, as far as changing out any hardware inside the ECM.
All I can do is tell you my experience.
My truck had 337k miles on it before I started getting that code and having the issue. I am the second owner and the truck was in hot FL it's entire life.
It was stalling and giving me that code pretty consistently for about a month and after I swapped in the Flashmaster ECM I haven't had a single issue with it since and it has been over a year and almost 30k miles ago.
YMMV, but my money is on the ECM as the culprit.
PG01
Up here to the right
Did you check the ground at the bottom left of the motor? There is a plastic clip on a stud and it holds a few wires in loom and on that stuf there are 3 ground wires 2 on 1 eyelet and 1 larger wire on its on eyelet.
Marky Dissod
No need to thank me for trying (failing) to help.
You need a newER ecm.
S
Scottm AZ
What tec 2 clone did you get? Is it possible to rent them anywhere?
I think the first thing I will do is change the crank pos sensor. That will always need the relearn, right?
kbuskill
NE. FL.
I bought mine from Chinacardiags.com years ago but it doesn't look like they list them anymore.
There is also this thread... https://www.tahoeyukonforum.com/threads/tech-2-owners-map.127187/
where members of the forum that own Tech 2s list there location. If anyone is near you they maybe able to help you out.
Also anyone with a decent bidirectional scan tool should be able to do the crank relearn.
I still genuinely think the ECM is the culprit but I also understand trying the cheaper/easier things first.
S
Scottm AZ
I talked to a local dyno shop yesterday about diagnosing, doing relearns and adjusting the tune. Of course they can do all that stuff.. They have a 2 hour diagnostic routine including dyno time for evaluation, at $200 an hour. For 400 I could get a good scanner of my own. But then I also want to improve the shifting and throttle response, but I'm not going to pay black bear $750 for a canned tune.
Rock Auto says the current OEM cps is 12703627. I also found 12585546 come up a lot on ebay. Does anyone know of any difference?
Fless
Moderator
People's Republic of Colorado
Blackbear's is a custom tune, not a "canned" tune. Tools like the Diablo tuners have several canned tunes, and can be used with some tuners (like https://diablewtune.com/) to craft a custom tune.
The one ending in 5546 has been superseded by 3627.
Fless
Moderator
After their diagnostic fee, what do they charge for a custom tune? And what's the fee for later adjustments, if desired or needed?
donjetman
Bought my crank position sensor (amazon) $50 in 2022, pt#
12703627​
S
Scottm AZ
Thanks PG, I got to this one today. Gave the wires a little extra crimp on the terminals too.
Charli1964
