2010 Tahoe dies in traffic in hot weather
Scottm AZ
Hi, my first post so I hope you don't think it sucks..
Bought a 2010 5.3 flex fuel 2wd Tahoe 3 months ago with 144k miles and in generally excellent condition. Beginning three weeks ago, four times now it has died in traffic on a hot day. By die I mean instant off and absolutely nothing happens when I turn the key to start. The first two times I was rolling and able to make it to the side of the road. Once it happened in the drive in line at Carl's Jr, and yesterday it happened when stopped at a busy intersection.
Each time after 5-10 minutes with the hood open, it starts right up like nothing happened. The cel comes on immediately each time it dies, and my scanner shows P0601, memory check sum error, permanent. A search on the code suggests it's a sign of a bad battery, so I bought an X2 from batteries plus for $414 two weeks ago. I cleared the codes and everything seemed fine since. I scanned it every day, and no codes were pending. Success, right?
Then it died again yesterday at the intersection. The common denominator is really hot weather. I'm in Phoenix, and each time this happened it was 110 or more. So I was ready yesterday with a water spray bottle, and sprayed the ecm for a minute. I also gave the fuse/relay box a rather angry side fist blast. It started right up and I was through the intersection in just one cycle of the stop light. So I'm not sure if it started from cooling the ecm or punching the relay box. It acts more like a bad electrical connection than a bad ecm. This morning I pulled the relays out one at a time to see if there were any loose or burned connections, and everything seemed fine. I drove it three times today in 113F and the cel has cleared itself.
Should I order an ecm off ebay?
kbuskill
NE. FL.
I was having the same issue in Hot (Florida) weather, replaced ECM June of last year.
Replaced the ECM after researching and finding others with the same issues and not a single problem since. Over a year and 30k miles ago without any issues.
Bought my replacement ECM from Flashmasters.
Only thing that sucked is I had to buy new credits for HP Tuners to be able to reinstall my custom tune.
S
Scottm AZ
Great, thanks! What was custom about your tune? I am annoyed by the way it shifts up and down and lurches like it cant decide what gear to be in. And the abrupt throttle response when you're coasting and get back on the gas. I wonder if I can buy an ecm from Black Bear with some adjustments in it.
solli5pack
I would do a lot more troubleshooting before condeming the ECM. Starting with the battery cables and grounds..
S
Scottm AZ
I found the Flashmasters tahoe ecm on ebay for $150. If the dying is common, then there must be some flaw in the ecm design. I wonder if flashmasters fixes something internally.
S
Scottm AZ
Thanks, I have suspected electrical connections myself. But it doesn't have other signs like crank weakly or flickering lights or shut down after hitting a bump. The connections at the battery are definitely good, but I will check the other ends
Welcome to the Forum from NH.
Pics of the truck, please. If we can't see it, it does not exist.
You wrote, "I cleared the codes and everything seemed fine since. I scanned it every day, and no codes were pending. Success, right?" This would suggest that there were other trouble codes, in addition to the P0601. What were they?
If you have a quality bi-directional scanner, it should be able to tell you what module triggered the P0601 trouble code, if it was in fact triggered by a module. Same with the CEL trouble code. What does your scanner show?
I recommend that you first check some of the of the other potential causes, before investing in a replacement ECM.
From Grok:
Most Common Causes​
  1. Internal failure of the PCM/ECM (or TCM) — By far the most frequent root cause. Age, repeated heat/vibration cycles, manufacturing defects, or prior electrical stress corrupt flash/EEPROM memory or the processor. Often called the “kiss of death” for the module.
  2. Power or ground problems — Low/intermittent battery voltage, weak charging system (alternator), corroded or loose battery terminals, poor PCM power feeds, blown fuses/relays, or defective ground straps/circuits. Voltage drops or spikes can corrupt memory or mimic an internal fault.
  3. Wiring/connector issues — Corroded, bent, or damaged pins at the module connector; harness damage; water intrusion.
  4. Failed or interrupted reprogramming — Incomplete flash, aftermarket tune, or power loss during programming.
  5. Less common — Shorted PCM-controlled output devices, physical damage to the module, or (rarely) software glitches that a reflash can fix.
Note: On some GM trucks (Silverado, Sierra, etc.), the code can originate in either the ECM or TCM; a professional scan tool is needed to identify which module set it. TSBs often exist directing technicians to verify power/grounds first.
Diagnostic Steps (Recommended Order)​
  1. Confirm the code(s) and freeze-frame data with a capable scan tool. Note any companion codes and the conditions when it set (especially coolant temperature, if available).
  2. Check battery health (≥12.4–12.6 V resting) and charging system (typically 13.5–14.8 V running, under load). Clean and tighten terminals.
  3. Inspect and test all power feeds, fuses, and relays to the PCM/ECM/TCM.
  4. Thoroughly check grounds — engine-to-chassis straps, battery grounds, and specific PCM ground points (common failure points on many vehicles, especially near motor mounts on GM trucks). Perform voltage-drop tests (should be very low, ideally <0.1–0.5 V under load).
  5. Visually inspect the module, connectors, and harness for corrosion, water, heat damage, or bent pins. Clean and reseat with dielectric grease if needed.
  6. Clear the code and road-test (including to full operating temperature). If it returns immediately or only when hot, the module is almost certainly bad.
  7. Rule out shorted outputs that could have damaged the module.
Do not replace the module until power, grounds, and connections are verified — this is the most common misdiagnosis.
Foggy
KS
After you get your issue resolved (could be battery cables or grounds) The
heat can cause your situation
You can do a transmission tune with HPtuners. You'll love the 6 speed once
you get rid of the some of the factory settings and adjust the shift tables.
Getting rid of the AFM and tweaking torque converter settings makes these things
enjoyable to drive. I absolutely hated the 6 speed in stock form. Now I love it !!
kbuskill
NE. FL.
I originally had a Diablo "canned" tune with AFM turned off, then I had Diablew do a custom engine and transmission tune. Then I added headers and had Lew redo my custom tune. Then I got HP tuners and have tweaked a few things since then.
My truck is an '08 Burb so it has the 4L60E transmission, so I have zero experience with the 6 speed. I did get rid of the PWM control of the Torque converter so it is either locked or unlocked like they were before.
My Burb now has over 365k+ miles on it, with AFM hardware still inside the engine, and just got back from a 7k+ mile family road trip at Christmas time with zero issues. Truck runs great.
S
Scottm AZ
Thanks foggy. I don't know if mine has AFM, is that the cylinder deactivation? What is the option code for that?
It's safe to say the battery and battery connections are good. And for the record, that's what a $414, 5 year full replacement warranty, X2 battery looks like. It's an AZ truck so there is no rust or corrosion anywhere. I pulled and cleaned the grounds that I could get to. The chassis ground from the batt cable goes all the way up to the front bumper and goes to the screw to the left of the body mount in the third pic. Why couldn't they put that screw behind that beam where we can reach it? I managed to loosen the screw one turn and crank it back down, which should be enough to reestablish good contact. I could not get a wrench on the ground strap bolt on the head behind cyl 7, but I could remove and clean the other end to the body. I may need to bend up a cheap wrench to get to the bolt on the head.
After 2.5 days of driving since the last 'incident' and about 8 drive cycles, I scanned it this morning and the only pending code is on the traction control, which may be due to a couple bad tire pressure sensors. Immediately after the engine dies it throws P0601, but then clears itself right away, usually before I can even get to it with the scanner. The last pic shows the rubber flap meant to keep air from going around the radiator has rotted away. I have not had problems with coolant temp, but the missing flap may actually be helping the ecm by letting cooler air get around the radiator and blow right on it, at least when moving. You can also see the spray bottle I keep up there to spray the ecm..
S
Scottm AZ
Couldn't it also be a crank position or other sensor? I have had them go bad on other trucks, but I always got a cel and code to let me know.
Fless
Moderator
People's Republic of Colorado
It could be; maybe try a crankshaft position relearn to see if that is successful. It's not conclusive, but if it's not successful you might consider changing the sensor and attempting the relearn. It's advisable to do a relearn when the crankshaft position sensor is changed or suspect.
Also, DTCs P0601, P0602, P0603, P0604 or P062F could set in multiple control modules. Can you tell in which module the DTC set? Is there a History code? Freeze frame data with the code?
Some diagnostic info here:
Forum tip: when "tagging" a member, start with the @ sign and continue typing the member's name, selecting it from the picklist once it shows up. Otherwise the member may not be alerted to your tag. I'll tag @Foggy here for you so he sees that you mentioned him in Post #10.
S
Scottm AZ
Ok thanks. I don't think my otc scanner can do the crank relearn. I took a pic, it says MOD $00
S
Scottm AZ
I think I'm going to get an ecm from flashmasters, only $150. I would pay a lot more than that for a guarantee that it will never die at an intersection again.
But apparently replacing the ecm will require the full monte crank relearn procedure. But it would anyway just for replacing the cps, right? Is there an affordable scanner that can do it or should I make an appointment with a shop?
Marky Dissod
plug&play, no crank relearn required, ever again.
Or, email [email protected] directly ...
S
Scottm AZ
That's awesome! How do they avoid the crank relearn?
Fless
Moderator
A crankshaft position relearn isn't always REQUIRED when changing the sensor or the ECM; many times everything will work fine. However, it's highly recommended to enable the ECM to know where the camshaft is in relation to the crankshaft. That can minimize random misfires and intermittent long crank times.
It's an easy, quick procedure, requiring no parts or disassembly. Do it for peace of mind and move on to your other issues.
John H Daniel
Before spending a bunch, check the big engine bay fuse box. My 2011 Denali did the same mysterious shutdown and a couple of other weird light things. Folks said the same stuff, grounds etc...
If you see my post about the fuse panel; it was corroded and some connections to relays, etc would randomly open. Cleaned it per some YouTube guy and never more problems.
Attached is what the bottom of the board looked like
thatboy_eddie
