I had no compression checked the rockers did not appear to be any play . Rotated them around slowly with covers off no play more than any others. Did compression test 0. Added some pb blaster I have 30. I'm guessing rings. I can get this engine for free I was just wondering if it's worth the trouble used ones are like $1800. The truck has like 250k on it but good shape but maybe not worth saving just part it out. Unless I get lucky and can get a whole 09 wreck or bad trans donor for 2k. Unless like you said I can swap the cranks or whatever use it as a short block somehow idk
Ugh. Yeah, that sounds like more than just failed lifter(s). The LMG will have to be disassembled and rebuilt, so you'd have no loss pulling the crank. Since the '06 (L59 or LM7?) will be out, you could take it apart and swap the crank. If swapping the crank, I'd recommend replacing the main rod and journal bearings and checking the clearances. Personally, I'd swap the reluctor wheel and keep the '06 crank in the '06 block. It's kinda sketch to do so, but you could reassemble it EXACTLY as it came apart (use new hardware), and you'd possibly, maybe even probably be good to go. I've disassembled and reassembled the bottom ends with original, non-refurb'ed parts on two engines (was requested due to super tight budgets and going in recreational vehicles) and they're still kicking with no problems as of yet.
You can extend the cam sensor wires to reach the front of the engine (you'll need to swap the LMG front cover onto the '06).
You can drill bosses into the block to mount your LMG knock sensors or keep the setup native to the '06 engine. Just know that using a different knock sensor style will require special tuning. You'll need tuning anyway to turn off AFM and to optimize for the "new old" motor.
Other than that, everything should be plug-and-play if you reuse your LMG intake manifold. If you wanna open up the '06, I'd suggest you swap on the heads (799 or 243- same thing) from the LMG if they're in good shape. They are superior to the 706s that are likely on the '06.
