2008 gmc yukon no crank problem
4pfTeejayiee
2008 gmc yukon no crank no start door locks not working power windows not working , prndl not working , dash board light not working
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
Welcome to the forum, from Oregon.
There are so many obvious questions. Did you try to jump start it? Replace the battery?
Good one day and bad the next? What attempts have you made to diagnose or repair the problem? Any recent work before problem?
4pfTeejayiee
Yes I tried to run it , I’ve replaced the battery
Welcome to the Forum from NH.
Pics of the truck, please. If we can't see it, it does not exist.
You are already receiving clarifying questions from the knowledgeable folks on this Forum.
You have not given us much information on what you've done, so far, in troubleshooting this issue, other than replacing the battery.
As such, I've asked Grok to troubleshoot your issue, using your own words:
Most Probable Sources (ranked by likelihood for this symptom cluster)​
  1. Poor connections at the 175-amp mega fuse (or related large fuses/cables) — Very common on 2007–2008 GMT900 trucks/SUVs. A loose, corroded, or arced connection at this fuse (passenger-side cowl/firewall area near the battery positive) can cut power to the underhood electrical center, starter circuit, and many body systems. TSBs specifically address intermittent no-crank/dead-battery issues from this.
  2. Bad or high-resistance ground connections — Especially main battery-to-engine/body grounds and BCM-related grounds (G103, G110/G108 on the engine, G201/G218 under the dash or driver’s footwell). Corrosion, looseness, or broken strands inside the cable insulation from vibration cause exactly these widespread electrical failures.
  3. BCM power/ground loss, failure, or network (CAN bus) short/open — The BCM controls door locks, windows (via door modules), instrument cluster/PRNDL, and participates in the starter enable path. A shorted module on the low- or high-speed network, chafed wiring, or BCM itself can drop multiple systems.
  4. Blown or poorly contacting fuses/relays in the underhood or instrument-panel fuse blocks — Especially large ones feeding the left/mid bussed electrical centers (LBEC/MBEC), instrument cluster, BCM, or starter.
  5. Ignition switch or related wiring (less common but possible) or residual issues after a low battery (modules “locked up”).
  6. Less likely but possible: Failed instrument cluster (PRNDL/dash lights are common failures on these years due to solder joints), or a shorted remote door-lock receiver or other module pulling the network down.
Battery replacement rules out a completely dead battery but does not rule out terminal/connection problems, a weak new battery, or the mega-fuse/ground issues that often surface or worsen after battery work.
Best Step-by-Step Troubleshooting Order​
Work from simple/cheap to more involved. You need a multimeter (or at least a test light), basic hand tools, and ideally a scan tool that can talk to GM modules (even a basic OBD-II reader is a start; a better one is better).
  1. Verify battery and basic power
    Measure battery voltage (should be ~12.6 V resting). Clean and tighten both terminals thoroughly (remove, wire-brush posts and clamps). Check cable ends for corrosion or broken strands. Try a known-good jump pack or second battery. Confirm the new battery is fully charged and load-tested.
  2. Inspect and test the 175-amp mega fuse (highest priority after battery)
    Location is typically on the passenger side of the cowl/firewall or near the battery positive (under a cover). Disconnect the negative battery cable first. Remove the nuts, inspect the fuse, cables, studs, and holder for arcing, melting, corrosion, or looseness. Clean everything, re-torque to proper specs (often ~11–15 ft-lbs; check a service manual), and retest. Many no-crank cases are fixed right here.
  3. Check all major fuses and relays
    • Underhood fuse block (driver side): Starter, powertrain, large 40–60 A feeds to electrical centers, instrument cluster (IPC), etc.
    • Instrument-panel fuse block (driver’s side of dash, remove cover): BCM-related, door modules, etc.
      Test with a multimeter (don’t just look—many “good-looking” fuses are open). Swap identical relays to test.
  4. Inspect and clean all major grounds
    Battery negative to body/engine, engine-to-body straps, G103 (right cylinder head area), G110/G108 (driver’s side rear of engine), and interior BCM grounds (under dash/driver’s carpet near parking brake or A-pillar). Disconnect, clean to bare metal, apply dielectric grease, and retighten. Look for broken wires inside insulation at the ring terminals.
  5. Hard reset the modules
    Disconnect both battery cables, touch the positive and negative cable ends together for 30–60 seconds (or leave disconnected 15+ minutes), then reconnect (negative last). This can clear logic lock-ups after a low-battery event.
  6. Scan for codes and check communication
    Use a scan tool capable of accessing body modules. Look for U-codes (lost communication), B-codes related to BCM/power mode, or anything pointing to network issues. Note which modules communicate and which don’t. No communication with the BCM or cluster is a strong clue.
  7. Further network/power checks if needed
    • Measure voltage at key fuses with key on.
    • Check for shorts on the CAN bus (pins 6 & 14 at the OBD-II port—should show proper resistance ~60 ohms with key off/battery connected in many cases; consult a diagram).
    • Unplug suspect modules one at a time (e.g., remote door lock receiver in the rear, trailer brake controller if equipped) to see if the network comes back.
    • Verify ignition switch power feeds and park/neutral signal if PRNDL is completely dead.
  8. If everything above checks good
    Suspect the BCM itself (common failure point) or instrument cluster. BCM replacement requires programming to the vehicle (dealer or capable shop). Cluster can sometimes be repaired for failed solder joints (PRNDL/odometer issues are frequent).
Most Likely Solutions​
  • Cleaning/tightening or replacing the mega-fuse connections or main grounds → very high success rate and inexpensive.
  • Replacing a damaged mega fuse or battery cables.
  • Repairing chafed wiring or a shorted module that was taking down the network.
  • BCM replacement + programming (more expensive, only after grounds/power are verified).
  • Instrument cluster repair/replacement if power is present but displays remain dead.
Safety notes: Always disconnect the negative battery cable before working on high-current connections or modules. These vehicles have retained accessory power and can have unexpected module behavior. If you’re not comfortable with electrical diagnosis, a shop familiar with GMT900 platforms (or a dealer) can diagnose faster with proper tools and diagrams.
Start with the battery terminals, mega fuse, and grounds—those resolve a large percentage of these exact multi-system failures. If you can report back voltage readings, which fuses have power, or scan results, more targeted advice is possible.
alexblagoev
