2008 Denali Towing Temps
Foggy
KS
I looked at the Mishimoto Radiators? Looks like they are almost $800. The specs look good but that is a lot.
I've had my mishimoto in since 2020. No restrictor mod needed. Been a great product. Has lifetime warranty. It's pricey, yes. I paid $500 in 2020 for it.
Zero problems. Towing very heavy (camper 9000 lbs)
kbuskill
NE. FL.
Curious what you average per year for mileage?
I think it makes more sense to look at it from a mileage perspective because obviously if a truck sits most of the time a radiator, or any part for that matter, will last a lot longer.
I'm not knocking the Mishimoto, I've only heard good things about them, I'm just trying to compare apples to apples.
Foggy
KS
I only average 5-8K miles per year. I DO change my coolant ONCE per year
with Dexcool and Distilled water 50/50 Mix. ( in all my vehicles)
kbuskill
NE. FL.
Speaking of coolant, does the Mishimoto require you to run Green coolant?
I ask because the Cold Case warranty requires the use of Green coolant.
Although, I will say that I have never been asked to provide any proof of that for warranty.
Foggy
KS
I run stock gm dexcool. Never saw anything that says otherwise.. IDK why
it would matter at all !!!!! Long Life Universal Coolant would be fine.
The old Green stuff is almost impossible to find and not compatible with any
late model stuff.. I don't even keep it or use it in any of my 'old' cars anymore
Just keep the universal long life in stock
Foggy
KS
Just to add: when I say dexcool, it just means it's the orange dexcool equivalent.
I usually buy prestone in the silver jug for all the GM stuff that has dexcool that
I work on. Everything else gets the yellow prestone jug that's universal long life...
even the Asian cars. I don't want to stock 10 diff kinds of coolant !!!
Sounds like you made many positive changes to keep temps down. If I read correctly you still have the stock radiator?
After hearing about the all aluminum radiators failing I cancelled my order on the 4 row radiator. Now I wonder if I should have just kept it and installed. This truck only goes maybe 4,000 miles per year but many times that is towing where I have found the cooling system is below par for this engine.
Years ago I worked for Kool Klutch / Eaglemotive, they manufactured fan clutches and tranny coolers. I have installed many tranny coolers without having one leak yet, never had to jump to AN fittings but I do like them for quality and endurance. The Kool Klutch coolers came with good quality hose and quality stainless screw clamps. Properly installed they worked fine. Company was sold to Hayden in the mid 90's. Dayco was the company that owned Kool Klutch. Dayco also manufactured and sold a full line of Hydraulic hose and fittings and crimpers. Did lots of hydraulic hose work, it is nice to have background, helps avoid failures normally. Transmissions only see about 300 PSI, in the hydraulic world that is not high pressure so it is pretty easy to seal up? My experience is from 1980-1990 maybe the newer tranny's put out higher pressures? I have not stayed up to date. I spent the next 30 years working on the Engine side of manufacturing.
mine with rubber hoses and worm clamps did not initially leak, but after about 3 years one vehicle began to seep pretty good and another seeped (pretty suddenly) a lot enough fluid to make a complete mess. my pet peeve is leaks (of any kind) so I nipped that with good fittings and hoses.
I believe external transmission fluid pressure on the 4l's and 6l's is only about 20-25 psi, which is plenty enough to empty the entire transmission in no time if the line came off
I drive a lot (i'm not easy on the pedal either) 10-15k per vehicle per year so probably around 25-30k annually
so those rubber lines and worm clamps were seeing max psi and heat, above normal conditions.
my reasons for 6an lines and fittings is simply for sealing & heat purposes and less about pressure
West 1
West 1
The new Radiator has come in from Rock Auto. CSF 3831, 1 1/4" thick core. Unpacked it looks like a really nice unit. The paperwork included claims they provide OEM radiators to many manufacturers and have produced 50 million radiators? True or false I don't know but the unit does look 1st class and profesionally packaged to avoid any shipping damages. Have not had time to install yet.
I drained the oil preparing for the oil cooler install. This oil had 2,000 miles on it, oil was dirty almost black. Cut the filter and it was perfect with zero metal inside. I don't know the maintenance history before 144,000 miles. It did not burn any oil but I am guessing it's early life saw a lot of miles between oil changes. I did tow with this engine several times on this 2,000 mile oil and the temps did get up to 230 or so on my gauge. Maybe I cooked the oil a bit?
With the new radiator I am adding in a factory oil cooler set up so that may help moving forward and the thicker 1 1/4" Raditor will hopefully keep temps down to 200* all the time.
My hope is the new radiator will cool the engine, engine oil and tranny oil better than the stock radiator. From the way guys have responded on this forum it sound like the 6.2L in these years did not have an adequate radiator for towing. Most report similar temps to what I witnessed?
I am tempted to see how it does towing so I will load the trailer and hit some choice steep hills to find out once installed. We are supposed to have a few more 80* + days this week.
Marky Dissod
I did tow with this engine several times on this 2,000 mile oil and the temps did get up to 230F or so on my gauge. Maybe I cooked the oil a bit?
I continue to voluntarily hold on to 'outdated' ideas about motor oil / ATF / antifreeze composition and susceptibility to heat;
I also have personally witnessed that when motor oil / ATF / antifreeze are stated to have hit 230F (110C) on a gauge or a sensor,
it must be true that somewhere some portion of the motor oil / ATF / antifreeze has suffered even higher temps,
because the sensors and gauges are placed 'conveniently' instead of being placed in the spots that are hottest when things get hot.
In other words, if it SAYS your coolant hit 230F, some of the coolant, AND the motor oil, AND the ATF, must've been even hotter than that.
Whenever any of my gauges/sensors report hitting 230F, I change all three fluids to err on the safe side.
My pcm tune also activates Hot Mode protocols/behaviors at 230F.
West 1
West 1
Fless, I pulled the radiator today, in between some other jobs on the house prepping for winter. The baffles you pointed out were both toast on each side. The best one was the driver side. It was torn free from the top and had migrated between the condenser and radiator blocking a large lower corner of the radiator from receiving any air flow. So thin they are absolute junk. The outer two baffles seem to be in place but the two on each side of the radiator were both shot and fully out of position. I am sure they were hurting my cooling situation. The new radiator from CSF is a nice looking unit but measuring it does not measure 1.25". I measured just under 1.2". The OEM radiator that came out measures 1.1". So this is not a big improvement although the fins are more concentrated so may be more effective. I ordered the new baffles, not happy, a lot of money for what seems to be a junk part from GM.
It may be a few days before I can get back to this, baffles wont be in till next week. I need to make some supports for the engine oil cooler lines I am adding so it will have engine oil cooling once done.
The factory type engine oil cooler takes up some of the cooling space inside the radiator so who knows if this move will help or hurt the engine temp cooling.
I revisited the removed engine oil, it did not look new but not nearly as bad as I presented yesterday, the container I used made it look darker. When I put it in a jug to go to recycle it poured out looking pretty good. It was still almost gold to medium brown color not black. The tranny fluid drained from the radiator tranny cooler today looked brand new as it should it has only about 1,000 miles on it since the Luk was installed so my temps were not high for too long.
kbuskill
NE. FL.
I revisited the removed engine oil, it did not look new but nor nearly as bad as I presented yesterday, the container I used made it look darker. When I put it in a jug to go to recycle it poured out looking pretty good. It was still almost gold to medium brown color not black. The tranny fluid drained from the radiator tranny cooler today looked brand new as it should it has only about 1,000 miles on it since the Luk was installed so my temps were not high for too long.
Some guys on here have used corrugated plastic, like yard sale/real estate signs, to make new baffles using the old ones as templates. It seems like a more permanent solution than the rubber the factory uses.
Just a thought, if you wanted to return the ones you bought and make your own.
Which reminds me, I still need to do this myself.
Marky Dissod
The GM OE engine oil HEAT EXCHANGER is meant to help the engine warm up quicker - it's not a cooler.
If the ATF or the coolant overheats, the engine oil HEAT EXCHANGER will also eventually overheat.
A motor oil COOLER would be separate from other heat sources.
I may take a look at that since the OEM design is flawed.
To GM the OE design is a feature.
West 1
West 1
The GM Oil Cooler in the radiator is an Oil Cooler. GM added it on all HD Tow Packages but it is not added in the light duty packages. GM believes it is a cooler.
Oil temps rise higher than radiator temps when an engine is working hard. 250* is not unusual for oil temps but we don’t have a gauge for that.
I believe it is stated that oil temps above 270* start to break down, synthetics protect at higher temps. Cooler than that is preferred obviously.
AI says oil flows best between 195 and 220 so keeping it at radiator temps is favorable.
Marky Dissod
Believes?
How GM handled the 8L80 shiver, and the L87, says a lot about GM's beliefs. I believe in better resolution/precision.
Oil temps rise higher than radiator temps when an engine is working hard. 250F is not unusual for oil temps but we don’t have a gauge for that.
GM does, they're OE for 'vettes, but GM believes suvs & trucks don't need it.
Also, when oil temps rise over radiator temps, this will cause the coolant AND THE ATF temps to rise as well.
In other words, what GM believes is a motor oil cooler IS ALSO A HEAT EXCHANGER.
HEAT EXCHANGER is more precise and less misleading than 'cooler'.
I believe it is stated that oil temps above 270F start to break down, synthetics protect at higher temps. Cooler than that is preferred obviously.
AI says oil flows best between 195F & 220F so keeping it at radiator temps is favorable.
For better precision, there are synthetic motor oils (mostly Group3 'synthetics', look it up) that begin offgassing as early as 248F.
Most Group4 synthetics (which are more synthetic than Group3 synthetics, I am not making it up) don't start offgassing under 266F.
If motor oil flows best between 195F & 221F, why do carmakers lean so hard toward 221F?
(AI believes NOTHING, and believes IN nothing, except maybe robbing OUR collective knowledge from us ...)
West 1
West 1
Marky, long before AI I worked for Federal Mogul for 30 years, we made engine bearings and dealt with all complaints from customers be that GM or the local Production engine builder. I have been in many. meetings with the guys that design the bearings and advise how best to keep them alive for long life. Sad part is every day i am finding things I knew are fading from memory and I have only been out of that since 2019 but I do have a very solid base of knowledge from real people that knew what it takes to make an engine survive. They were the engineers, I was in the middle, customers asked questions and I had to go to engineering to get answers for them. For me it was a very interesting job, I loved it. Something new almost every day.
We also owned Fel Pro Gaskets, Moog Chassis, Wagner Brake, Champion Spark plugs, Sealed Power Pistons and Piston Rings, TRW forged pistons, all Valve train parts and most internal engine parts but at the OEM level we were a main engine beairng supplier for many years. In the later years we also owned Beck Arnley for import parts, Ferodo Brake the largest European brake company and many small companies that made parts for OEM, Lots of exposure to what makes parts fail or live. I worked with all of these products but spent most of the years as an engine specialist, the last 7 years as a Diesel engine specialist.
I have seen where the OEM cuts corners and the customer is hung out to dry but most times they have very solid reasons for the way things are built. I try to follow their lead most times.
Each and every vehicle has it's own unique challenges or typical failure parts. A forum like this one helps share all those unique solutions to keep the old beasts on the road.
I will report back once the new radiator is in and the baffles added back in. ( not blocking the lower corner of my radiator......GRRRRRRR.).
For now I have an OEM factory radator with nothing wrong with it if someone needs one for a 4.8 or 5.3L. I will probably list it on craigslist and let it go cheap.
Fless
Moderator
People's Republic of Colorado
The political yard signs are also a good source this time of year (after the election).
Marky Dissod
@West 1, I'm well aware of your impressive experience, and willingly admit that mine can't hold a candle to yours.
That said, from the day I got into cars, I was always into the idea of MEASURABLY improving them, somehow.
Schidt, that's how GM came up with the '94-'96 Impala SS in the first place.
When I settled for a '94 9C1 LT1, I was lucky enough to discover the Impala SS Forum,
arguably the intersection of the most enthusiastic AND most technically experienced and literate modders I've ever witnessed.
Vast majority of them did not want to settle for what GM was willing to sell, or at least market -
instead of following GM's showroom floor leads, they (and eventually I) treated the entire GM parts dept as 'Legos',
to see what would work together well and improve on what they'd bought.
3.73 instead of 3.08, limo suspension steering and cooling kits, Astrafari front brakes, LT1 Camaro/FireBird-inspired intakes, stuff along those lines.
The guys who tried adding a Panhard bar or a torque arm were considered a bit excessive;
the guys who Frankenstein'd 4x4 Caprices / RoadMasters by using GMT800 Tahoe frames suspensions & steering assemblies were considered a bit more excessive,
the guys who fantasized about upgrading to rack&pinion steering were let down gently when we managed to determine as a group
that redoubling our focus on local frame rigidity was a far more cost-effective investment with measurable handling improvements,
the guys who sought to upgrade the Opti-Spark cooperated with and shared info with those who sought to update to GM OE LS-type ignition ...
even after a catastrophic data mismanagement calamity caused the loss of the majority of the ISSF's collective brainstorming from 2000-2009.
I have seen where GM OE cuts corners and the customer is hung out to dry, but most times they have very solid reasons for the way things are built.
No Caprice RoadMaster or Fleetwood can go from a low-15sec 1/4 mile ET to a low 13sec 1/4mile ET, while not losing any MpGs, by following GM's lead.
People like you are FAR more qualified than people like me to improve on what GM was willing to sell us.
Each and every vehicle has its own unique challenges or typical failure parts.
It would be nice if it were possible to upgrade typical 1500-type parts with 2500-type parts, no?
I for one am glad for the GM OE 2010 front brake kit update/upgrade, dream of a Z60/Z85 handling package for my Tahoe,
and am next looking to delete the tensioner pulley / update the front accessory drive.
Tight budget automotive enthusiasts are prime suspects for ... re-purposing political yard signs.
They make pretty good heat shields, and are useful for rough draft-crafting.
Chris2144
I remember in the 90s my 98 1500 was a heck of a truck.
Pulled a 9.5 6 lug axle from a 2500 and it bolted right in. Added an extra spring to the packs.
Nv4500 was a direct replacement as well.
Fan and clutch from 2500 dropped right in.
That truck hauled so much stuff and went places off road it had no business being in.
I hauled a couple yards of sand and two pallets of flat stones for a back yard remodel one time the rock company looked at me like I was crazy. Said you know that’s a little over 10k on the trailer right.
The trailer had good brakes and so did the truck and it hauled it great. Stopped good too.
I love how the gen 3 ls platform is very interchangeable. Gen4 is much of the same.
alexblagoev
