Phil Van Beveren
- Joined
- Nov 7, 2019
- Posts
- 9
- Reaction score
- 2
Been fighting this for about 2 months.. Battery holds up for about 6-8 hours while sitting at work, 9 or more hours sitting over night and the battery is dead enough it won't start the truck. Replaced starter, no help, pulled alternator and had it tested and it is good and meets all standards. Also replaced the battery in April of this year.
Put an amp meter between negative cable and negative post on battery (in series) and it shows about a 2.5 amp drain. Started pulling fuses. The radio and radio amp fuses reduce the drain by about 0.9 amps so don't think this is it... Pulled the TBC2 (Truck Body Control) fuse and drain reduce by over 1.5 amps... think this might be it.
I have had some minor issues with the Body Control Module but disconnecting the battery for about 5 hours and letting all the energy drain out of the BCM cured the problem.
Any thoughts or ideas on where to look next now that i know it's in the TBC circuit somewhere would be greatly appreciated.
Regards
Phil
P.S. I installed a cutout switch between the negative battery cable and the negative battery post to stop the drain so i don't need a jump start every morning.
Regards
Phil
