2006 XL2500 6.0l P0300 code
Chazcon
Hi all, my first post and probably been done to death. Im in Ausrtralia with a 2006 XL2500 Yukon, steering converted to RHD. We’ve had the car for about 12 years with minimal issues….until this year. Started with O2 sensor code, replaced upstream sensors and the code went away. Shortlyb after that got a P0304 code, cleared the code and it didnt return for some time. Then the transmission died. Had the trans rebuilt and p0300 code continued to appear more often. Now it returns regularly.
With a can tool showing live misfires on cyl 4 and 3. The parts canon has been fired. New Delphi MAF, Felpro intake and valley gaskets, new knock sensors, 4 new Bosch O2 sensors, 8 new NGK Iridium plug, new Accel ceramic plug wires, injectors removed cleaned and tested professionally. I have swapped coil 4 with coil 2 and coil 3 with coil 5 with no change, swapped plugs from 4 to 2 with no change. Had a compression and leak down test done professionally and all good.
Misfire is only at idle and clears once above idle. The idle appears to be quite low at around 550rpm when warmed up. I have checked body ground wires under the LH front door, as well as the one at the back of the engine. I have run a heavy ground wire to the coil bracket. Injectors are “clicking” so im anssume anre injecting and coils are firing. I will do a fuel pressure test on the weekend. After that i dont know what to check all suggestions are appreciated TIA.
Fless
Moderator
People's Republic of Colorado
What misfire counts are you getting?
FWIW I would do a Crankshaft Position Variation Relearn with a scan tool to rule it out as a cause.
At hot idle, what does the scan tool say the MAF reports in g/sec (not lbs/min)?
Also, look at the short- and long-term fuel trims at both idle and around 2k rpm. Post those up for us to see.
Chazcon
Chazcon
I will get back to you Friday night when my son brings his scan tool back. Thanks
Chazcon
Chazcon
Misfires were around 70 on cyl4 and 20 on cyl 3. Misfires group to 0 above idle. We are also moving interstate in a week, 1400klm south, so i might be slow with information.
I am looking to buy a scan tool for myself. I am leaning toward the Tech2 clone but worry it is complicated to use looking at it. Any advice on the thech2 or another scan tool would be great.
Fless
Moderator
When the injectors were replaced were new o-rings used?
And were they marked as to cylinder location and returned to their respective holes, or were they reinstalled randomly?
Chazcon
Chazcon
I assume they were all new seals, the place that did it were a reputable shop. As far as going back to where they were originally, I’m not sure either. I again, assume they went back in the same place. My very first code with this issue was a P0304, then went to p0300, and it’s cyl4 that still has an issue. I have swapped injector 2 with 4 at the moment.
Chazcon
Chazcon
I have some snap shots from my old basic scan tool. I’m not sure if it means anything significant, but the long term fuel trim seems to sit higher on bank 1. I also got a p0304 this afternoon. MAF reading was ranging from 6.9-8g/s
Marky Dissod
Try swapping the misfiring injectors to cylinders 1 & 2.
At the very least running Chevron w Techron Fuel System Cleaner double strength
(2 fullsize bottles to one full tank or 1 fullsize for every 12 gallons)
Chazcon
Chazcon
Thanks Marty, I have had a full tank of cleaner through. Again this was a commercial cleaner, not off the shelf in a store. Is there a reason you say to swap 1 + 2 injectors. The misfire is on 4 + 3, predominantly 4. I have swapped 4 +2 with no change.
Marky Dissod
Thanks Marky, I have had a full tank of cleaner through. Again this was a commercial cleaner, not off the shelf in a store.
Is there a reason you say to swap 1 + 2 injectors? The misfire is on 4 + 3, predominantly 4. I have swapped 4 +2 with no change.
If your fuel cleaner lacks Poly Ether Amines, it basically lacks fuel cleaner, at least in terms of potential misfire mitigation.
Short story longer: try swapping the injectors FROM the misfiring cylinders, TO cylinders 1 & 2.
Chazcon
Chazcon
Thanks Marky, I’ll give it a try over the weekend. Im moving house in a weeks time so im going to have to drive it as it is at this stage. But I really appreciate the suggestion and would love to know the story behind it.
Marky Dissod
Wish I'd a truly chemical understanding of what Poly Ether Amines do, but I've witnessed cleaners with PEA dissolve carbon buildup firsthand.
Here's an incomplete list of cleaners with PEA
Chevron Techron Concentrate Plus 01154100-5179P
Gumout Regane High Mileage Fuel System Cleaner
Gumout All-In-One Complete Fuel System Cleaner
Lucas Oil 10512 Deep Clean Fuel System Cleaner
Gumout Regane Complete Fuel System Cleaner
Red Line SI-1 Complete Fuel System Cleaner
Not sure about BG44K, but I do know that several carmakers have rebranded BG44K as 'their' formula for pouring into the gas tank.
Bet a search with a 'friendly' AI would give a more up-to-date list of fuel tank additives that contain PEA.
Other thing I've learn myself from both experience and anecdotal data is that it's ok to go with any of the above cleaners at double dose strength with *petrol.
So when you go for that drive, grab several bottles of anything on the above list and pour one in for every 1/2 a tank.
Chazcon
Chazcon
Hi guys, did anyone get a look at the pictures of my scan tool. Is anything of any help there. My son couldn’t get to my place to plug his fancy scan tool in. Hopefully tomorrow I can get it scanned properly.
noodlesandsam2
NYC Metro
I've had some Misfire and knock sensor code issues. I've narrowed a few things down - It happens when the tanks drops below 3/4 full - above that I am fine. Are your issues agnostic of fuel levels? There was also a thread else where - not on this forum - where a P0307 ( cyl 7 ) consistent issue was traced to a wiring fault to that injector. Which engine do you have 6.0 liter ( LQ4/LQ9 ), or 8.1 Big Block? - guessing 6.0
Chazcon
Chazcon
Yeh I have the 6.0l. Im certain fuel levels dont affect it because it’s been there from full to low tank levels. Im beginning to think wiring but it gets much better just above idle. If i drive with my foot on the throttle when i stop, just holding that revs up a bit, i dont seem to get a misfire code.
Did you get the opportunity to see what your fuel pressure is at idle?
Chazcon
Chazcon
I have made no more progress. I have had to admit defeat and take the Yukon to the shop. I have only 7 days to go till we move 1450klm south. All my tools are packed in a shipping container ready to be picked up in a few days. The Yukon will stay behind and we will return in November to hopefully pick it up all repaired. I will update with anything new or what the problem is when i hear. It’s probably something dumb like a fuse.
Chazcon
Chazcon
Well I’ve run out of time before our move. I’m dropping the Yukon off at the shop that rebuilt my gearbox to find the issue.
alexblagoev
