bobbinali06
- Joined
- Sep 2, 2026
- Posts
- 2
- Reaction score
- 1
I have a 2006 gmc yukon denali that i brought just about a month ago. A couple weeks ago the radiator bursted a massive hole and coolant went everywhere. The car was sitting outside idling while I was waiting for an order to be made. Ive had no issues with it getting hot up until that point, but I think my issue couldve been the fans not turning on mixed with the car being parked infront of a wall and idling for about 30 minutes so it overheated. Luckily I shut it off just after I noticed coolant pooling and smoke billowing out from the hood.
Anyway, everything's installed back in the vehicle with a new radiator, but the fans wont come on. Ive read that turning the ac on as low as it can go and turning on the recirculation will kick them on but they didnt. Ive also got 2 scan codes that are just "fan circut 1" and "fan circut 2". I swapped both the plugs and it changed nothing. It also has a brand new coolant temp sensor. Im going to assume the relays are bad and if im not mistaken its the few fuses and relays behind the large fuse box under the curved metal bar? If so which fuses need replaced or how can I test if its bad?
Im no good with electrical stuff and fuses and the diagram doesn't show the other smaller fuse box. Any help would be greatly appreciated
