2005 yukon denali - body molding removal?
tahoeyahoo
can this side molding above the side step be removed? if so what is under? thanks
chadw
Of course it can. Its double sided taped on only. It comes off and then itll look like every other base model yukon out there.
J Mac
Newport News, VA
Once you pull those panels off, the running boards look horrible on the truck. Those panels are much thicker at the bottom then the top. I pulled those panels and running boards off my Denali because I just didn't like the look after I lifted the truck. The rear quarter panels on mine were hiding a lot of rust so be ready for that possibility. I used a heat gun and just pulled the panels off. WD40 and some good ol' elbow grease to remove the leftover tape.
